0-300 Cylinders
What mfg. produces the strongest cyl for a 0-300 ? TCM Superior ECI
7853H offline
136
Old and still keepin it up --
River rat offline
750
ccurrie wrote:NOT ECI !!!!!
Uh Oh...I've been very happy with the Titans in both my 180 and Champ. What am I missing?
Mike
skywagon63d offline
26
within 200 hours from brand new one cracked one head broke off and a 2x3 inch chunk of crome fell off and went into the engine. We contacted them and got no help whatsoever. so $10 000 later all I can do is badmouth them every chance I get and hopfully prevent somone else from wasting there money, or worse!
River rat offline
750
ccurrie wrote:within 200 hours from brand new one cracked one head broke off and a 2x3 inch chunk of crome fell off and went into the engine. We contacted them and got no help whatsoever. so $10 000 later all I can do is badmouth them every chance I get and hopfully prevent somone else from wasting there money, or worse!
Bad news! What kind of engine, and how long ago?
Mike
skywagon63d offline
26
It was a IO-550 I hope you guys that have them have better luck than we did. the guy who does our engines now wont install them even if the customer brings them in he will loose the work rather than have his name atached to an engine with ECIs on it!
River rat offline
750
Fri Nov 19, 2010 10:14 pm
I \put a set of steel ECI cyl's on a C145 at major in 1991 & it was still going strong at 1100 SMOH when I sold it 8 years later. I did have trouble after several hundred hours with a couple exh valves sticking. I went through & checked all of them after the second one stuck- a total of 3 or 4 required reaming. These smaller Continentals are notorious for loose valve/guide clearances requiring new guides well before TBO, so I think ECI just sets them up really tight. Probably a good idea to double-check the valve stem/guide clearance before installing a new cylinder, instead of assuming that it's right.
10534
Fri Nov 19, 2010 10:19 pm
ccurrie wrote:It was a IO-550 I hope you guys that have them have better luck than we did. the guy who does our engines now wont install them even if the customer brings them in he will loose the work rather than have his name atached to an engine with ECIs on it!
The really sad part of that story is that ECI was so unresponsive. My experience with them has been just the opposite. Hope they have turned over a new leaf.
Mike
skywagon63d offline
26
