jomac wrote: turbo-normalizing it...this works real
well in the back-country,
There are a lot of tricks, even for a certified engine to get more power. If you figure out the actual power increase per dollar you would be shocked. Nothing will make power like always having your engine breath sea level pressure, if you can afford it it's they way to go.
I overhauled my I/O 540 W1A5D a couple of years ago, went with new millenium cylinders, Gami injectors, etc. If I had to do it again, I would go with Lycoming cylinders and left the injectors alone etc. You can spend a lot of money and not get much for it on an engine. The bone stock engine has lasted 2700 hours, can you beat that with anything aftermarket? It wasn't available for me, but if I could go with the new Lycoming roller cam, I would if I were you.
Price a Factory overhaul, It's been my experience that they aren't that far off, a little more, but certainly in the ballpark.
