Okay, I think I'm understanding what you're describing now. Yes, when the MT prop (actually the MTV 15 prop--they named it after me....
) goes to full fine pitch, it creates a lot of drag. This is just one of the tools you can use to smoothly fly relatively steep approaches, and also to get to the point where you really can hit your desired landing spot consistently. Carry a touch of power right up to the flare, then pull the throttle back, and the airplane will land.
If that's what you're talking about, yes, this is perfectly normal for the MT. Frankly, I love that feature of the prop, because it really permits steep descents and very positive control of descent rates and touchdown.
I wouldn't worry too much about engine failure in the MT. If it fails with the engine turning, pull the prop control all the way to coarse pitch. If the engine stops, no worries, cause a stopped prop provides very little drag in any case.
One of the things that really gets people's attention with the MT prop is there's almost no flywheel effect on start and stop. Start it, and it just starts, no spin up. Shut it down, and the prop stops. Now.
Keep us posted.
