1954C180 wrote:Gary, the plane picture is configured via the "signature" part of your
account. Personally, I used Paint Shop Pro, and used the "magic
select wand" to select and remove everything around the airplane
and deleted that, ...................
Both the Penn Yann and the Great Plains conversions use a fixed pitch prop. If you are going to the expense of putting a new engine on your airplane, I'd recommend going the whole way and installing a constant speed prop as well.
Particularly in this day of high fuel prices, the constant speed, while costing more to buy, will save a lot of fuel money over it's life span.
The early 180's apparently did have bladders, with a 60 gallon capacity, but were rated at 56 useable, which means you could use it in any normal flight attitude.
The rental 172 that I used to fly had a PowerFlow exhaust on it. I hated the noise, after about one hour of flying that constant throbbing roar would just start grinding on me. It had a funny way of being fatiguing, that constant sonic assault just wore on me. Just food for thought. If you haven't you might want to spend a couple hours in a plane that has one on it before spend the dough.
The rental plane had the older style that exited straight back. It sounded great at startup/idle, but it was just to loud going cross country. Of course there's a lot of variables in play there, but I bet just pointing the thing down like a stock exhaust would make a noticable difference, and I didn't have an ANR headset then either.
Another aspect of that origional style with the rear facing extension on it that I didn't really admire was the way it hung. I had to tighten the clamp on the hanger a couple of times. It just had a lot of pipe hanging out vibrating around.
The new style will be just about as much of a pain in the neck to remove the cowl. These things cost a LOT of cash, for the minor benefit, in my opinion.
mtv wrote:Well, that may be for a 172, but I doubt it. That stack is about a foot longer.
I was looking at a PA 12 today with such an exhaust, and they're having to build a whole new lower cowl because of that stack.
It's a LOT longer, and sometimes that in itself requires some additional machinations to remove.
But not always,
