180/185 Float Plane Spreader Bars
I am wanting to build a spreader bar/lifting frame for my 180. My 180 does have the lifting eyes. I have a few thoughts how I would like to build one. Will y'all share photos or drawings of ones that are used?
Bearhawk_Cub offline
32
- Aircraft: Cessna 180K, Bearhawk project.
Bearhawk_Cub wrote:I am wanting to build a spreader bar/lifting frame for my 180. My 180 does have the lifting eyes. I have a few thoughts how I would like to build one. Will y'all share photos or drawings of ones that are used?
Here is a pic of the spreader bar I built for my cub. Should be able to cobble something together solitary for 180.
PS.Spreader is hanging in the wall in background
N9PW offline
3
- Aircraft: CarbonCub EX
Is this one of those social experiment threads? [emoji15][emoji3]
gbflyer offline
2317
Mon Mar 13, 2017 10:14 am
N9PW wrote: ....PS.Spreader is hanging in the wall in background
What background?
10534
FWIW, every time someone posts a picture using tapatalk, I just see a little box with nothing more. Clicking on that box to put it into a new tab, a message tells me that the tapatalk protocol isn't supported. Since I don't understand all that stuff, all I can say is that tapatalk doesn't work very well with pictures.
3801
I think I got gypped , my float plane did not come with one of those .
Little John offline
250
- Aircraft: Maule, Citribria
Does your airplane have two lifting rings or four? Assuming four, I'd build it with an X, spreading the slings diagonally. Then you can fold it nearly flat for storage. Building a rectangle or an H is harder to build and store.
I use 12' long slings and no spreader. I've got three crane trucks to chose from, so the sling length isn't an issue. It's been suggested that I'm imposing some harmful side loading. I don't think so.
Pinecone offline
996
- Aircraft: Cessna A185F
I got this on a seaplane email list years back.... it should do the trick:
If you have the headroom, you don't need a spreader bar arrangement so long as your lifting cables are at least 60" long. Shorter than that, and they'll put too much side load on the lifting rings.
Chris
airChris offline
99
Thanks for the responses. As much a I like pretty woman and I know the pilot humor. I can say I disappointed that there was no spreading involved.
. I am sure the censors would have removed.
The last drawing is what I was thinking the middle having a 1/4 or 3/8 1.5'' strap with mutable holes for adjustable lift points.
32
aqua offline
237
