This is a bushplane, and kept it functional and simple. If it was too fancy, I wouldn't have been able to get it dirty with fish slime or moose blood
swixtt wrote:Looks great. Very functional. It will be nice when you redo your seats. Hopefully you're getting them bolstered up a bit. I'd be very curious on the paint you used and process? I'm doing the same on my 170b but haven't decided on the paint yet. Also what hidden fastener did you use for the alum covered door panel? Assuming would be very similar to mine.
corefile wrote:What is that pulley mounted above your trim wheel?
swixtt wrote:The paint process was simple. I used Klean Strip Aircraft Stripper on the paint (very good), primed with two part epoxy in grey, and painted in dark grey enamel. I removed everything that was removable and sprayed it, and rolled the door sills with a small fine roller.
The door panels are attached by 3/8" upholstery spring clips. I couldn't find a picture of them anywhere, but they are very simple. They are basically an X shaped spring set into a snap head. Once pushed into a drilled hole, they firmly snap in. As far as I know, they are original.
sounds like the same clips i HAD on mine. they were in terrible shape so we went with a plastic retaining insert but i'm leery of these as the teeth in them will surely fail when i need to pull the door panel off again. wish i could find those metal upholstery type clips somewhere.
thanks for the info on the paint to you both. as Rob mentioned, which is good advice, i've seen planes done both ways. i'm planning utility selkirk foam for the back section and possible matching seat covering nearer the front. mine is a flying project so i do small sections at a time. mostly spending time removing glue, old paint, etc.
anyway, keep up the great work .... if you get a chance to post a pic of your seats that would be great!
