Fri Aug 03, 2007 11:13 am
Zane...you might want to split this thread into something like "find ravi a plane so he will quit whining"...what I've learned about 180 legs is if the plane comes with them, fine, otherwise don't worry about it.
I really don't have anything concrete to base this on, but I've wanted to stick to a four cylinder Lycoming because I think it will be less expensive to maintain, operate, and eventually overhaul. Perhaps I've just been imprinted by seeing one every time I check my oil.
Such engines are rather rare in the used Maule market, at least with the constant speed prop. I've heard the argument that you just throttle back a bit with a larger engine and you will get the same fuel burn as with a smaller engine, but I have personally never found this to pan out in reality...not with motorcycles, cars, or the one plane I've ever gotten to know.
Fully clothed and soaking wet my wife and I only come to 320 pounds. We both have irregular schedules which all but preclude normal social encounters...I can think of about three times in the past year it would have been nice to carry a third or forth person. We want a four place plane for the cargo area more than the seats.
Right now I have a plane that is almost perfect for one person, but just not quite enough plane for two people. Even with its limitations, we've had a blast! Gravelly Valley, Ocean Ridge, Shelter Cove, Ruth, Moab, Truckee, Blue Canyon, Quincy, Sierraville, Cederville, Bishop, Alpine County, Salt Lake, Pocatello, Stovepipe Wells, the Chicken Strip and around a hundred other airports... The little plane has gotten us there and back.
A big part of our enjoyment has simply been that the cost of operation didn't dissuade us from using it. While I'm ready to pay for more performance, I'm not ready to buy so much performance that I have to triple think whether I can afford to fly this week.
I have rather convinced myself that the Lycoming 180hp engine is going to be substantially less expensive than any of the slightly larger six cylinder engines. Am I way off on this?
