180 Toe In
I have a what I think is excessive toe in on my 180 causing some ground handling issues.
Using the straight edge in front of the tires and a carpenters square off the disc I am showing a 1/4” toe in measured at the gap between the square and the straight edge. From what I have read I believe it should be 0 to 1/16” per side.
Looking for some experienced Cessna guys to chime in.
Thanks!
Wilson offline
26
- Aircraft: Cessna 140
Cessna 180
Wilson wrote:I have a what I think is excessive toe in on my 180 causing some ground handling issues.
Thanks!
Are you putting the plane on grease plates when you do that measurement? It needs to be a grease plates to do it properly. Should also be at gross, or close to where you regularly fly it for weight. 1/4" is to much if yoy are doing it on grease plates.
5186
Yes, trying to adjust gear alignment in one of these things is hopeless without grease plates. Cheap and easy to do. Get it on plates, then jockey it around till it settles out, THEN measure.
10514
I agree with MTV my 170 had a lot of excessive Tire wear and it was a little hard to handle on pavement. I use a pair of grease plates and luckily I had enough shims available to get it pretty close.
I was just out on New Year’s Day with the previous owner and he commented that it was behaving very well on the pavement.
richw56 offline
124
- Aircraft: Cessna 120 125 Lyc.
Yep, I had it on grease plates. I guess it’s time to get some shims and get to work.
Now can anybody tell what the max toe in should be? Is it 1/16” per side or total?
Thanks!
Wilson offline
26
Cessna 180
You want it as close to 0 as possible at your normal operating weight, and max of 1/8", so that would give you 1/16" per side.
5186
Thanks for the info guys!
Wilson offline
26
Cessna 180
