Well, it isn’t going to be cheap but it WILL be done right which that in of itself is worth a lot. Going to be a sweet airplane when you are done! Thanks for posting and letting us follow along.
aqua wrote:On straight floats I’d characterize the inboard filler caps as essential. Climbing out to those outboard caps while at the dock will be a continuous PITA.
PNW Flyer wrote:i will post these just because I have been frustrated trying to find cost numbers in the past. The labor cost to the first of June was $16,600. There was, of course, a couple weeks more work to get it to the point of the "off to paint" picture in mid june. I will update when that bill comes in. That does not seem too bad considering the addition of the SPW kit alone is estimated at something like 120 to 150 hours.
And then paint will be somewhere in the $15K range depending on how much corrosion they find.
And then assembly (wings and tail, engine, float install) is estimated (guesstimated?) at about 100 labor hours. I will update those as they turn to actuals.
