I carry 50 pounds at the most rear baggage area and with this I had the plane just in the middle of the CG 39 inches.
Behaves very nicely, with this CG and the Sportsman kit just me and half fuel, its a nice fun performer.
Im doing a couple mods to my 182 P.
MT prop 2 blade (15 pounds less)
Selkirk extended baggage
I did a new weight and balance calculation ,and with the new prop plus 25 pounds at rear of the new extended baggage, and the old 50 pounds removed.
Now will be at the same CG with 40 pounds less.
Since Im at this. I Need to buy a new front tire so wanted a light one, anyone knows about a brand? 5 x 5.00 6 ply. (I know wont be much ,but if I can get it why not).
Also I might keep a bit more weight in the new extended baggage, maybe 30 or 40 pounds, to have a CG a bit more to the rear.
Now the more the rear CG the most abrupt the stall correct? I know will be at lower speed but the stall will be more violent?
I do lots of stalls the way the plane is now and its very docile, but never have done stalls with the plane full of people and heavy which is usually with a rear CG.
