Mark Y. wrote:Ya - Doesn't seem so bad to do the wiring after wrestling with tray moving and mounting. Especially big trays like these are. With newer thin com radios might even be able to fit the transponder in the center stack too. I have replacing the intercom next on the list so i will be digging into the wiring anyway. Amazing what shoddy work some avionics places do, Trays installed with only one screw in each side - tinnermans for backing, next to non-existent rear supports. Granted the radios were put in in the early 80's, but still. Always wondered what the shudder noise was when I manually lifted and lowered the elevator from the tail - rubbing on radio tray.
Took me a couple 5 hr days to do. But I did preorder everything i anticipated needing: 50 thou panel stock, bolts/nuts, aluminum bar stock for radio tray supports, guage reducers to move guages from rh panel to lh, primer, flat black paint etc. I ordered the airgizmos mini ipad mount and the angle piece for it, but no real good place to put it unless I did the full engine monitor and got rid of the fuel/oil guage cluster. I ended up using a MGF aluminum mount - really nice and solid and looks like part of the panel. Pricey though. Ashby glareshield was easy, biggest task was guessing at the heat duct slot cut as windshield was in. Otherwise no trimming required, nice product.
There been some SL30s and 40s going for around 1800. Not cheap, but cheap for quat you get. And thy are very slim. But anything really. The TKMs work pretty good though for the price.Mark Y. wrote:I do like and somewhat need dual comms. The old 170 worked, but the ugly old MX12 was dead. The TKM's were the fastest, if not the cheapest solution at the time. $500US off of retail each Oshkosh discount wasn't too bad a year and a half ago. I will definatley keep an eye out for a new thinner com for a decent deal as VOR's will be a thing of the past sooner than later. Any particular ones you would recommend i watch for?
A1Skinner wrote:...I like just a single comm an intercom. No audio panel needed that way, so no avionics shop needed either.
Mark Y. wrote:....I have replacing the intercom next on the list so i will be digging into the wiring anyway. ....
