This turned out nice so I thought I would share.
Any guesses what 70’s IFR panel weighs?
Less the following: VSI, ASI, altimeter, turn coordinator all remained….
asa wrote:Perfect. Good work dude! What’re those things on far left?
frstnflt wrote:Nice job! What did you do on the lower panel? Is that an overlay or fabricated replacement. I find that to be the hardest part to decide. One big panel would be nice but a ton of work to remove the thr,pr,mix cables and make holes for ALL those switches.
skyward II wrote:Guess the removed 70’s IFR panel weight?
WWhunter wrote:skyward II wrote:Guess the removed 70’s IFR panel weight?
No idea...shot in the dark...32 pounds!
skyward II wrote:WWhunter wrote:skyward II wrote:Guess the removed 70’s IFR panel weight?
Great guess. 52 lbs including vacuum pump. It’s a heavy box.
Should help a bit with weight forward CG without passengers.
Simie580 wrote:You’re killing me Smalls. Really nice. I wish I could do that, but first up will be a FWF - over 1500 on my O470 with no problems, but …….
MooseMeat wrote:Keeping or selling? What a great project!
