185 Gear Shims
Anyone have a good source? I'm a bit out of alignment and annual is coming up so it is a good time to get things straightened out.
Thanks in advance.
JC
185Midwest offline
438
- Aircraft: C-185
185Midwest wrote:Anyone have a good source? I'm a bit out of alignment and annual is coming up so it is a good time to get things straightened out.
Thanks in advance.
JC
I assume you’re looking for axle shims? Or gearbox shims?
I’d start with Atlee Dodge in either case. Next stop would be Airframes Alaska. Last stop would be Univair.
10515
Grove makes some that are pretty affordable. They aren't for certified airplanes last I checked, but I bet if you put them on, your bird won't know that.
AEROPOD offline
479
I have a pretty good selection of camber shims available but only have a few shims to correct toe-in. Please call me at 308-390-5974 if I can help.
494 offline
26
Thanks all. Yes Mike axle shims.
494 I'll give you a call.
I appreciate the help everyone!
MW
185Midwest offline
438
- Aircraft: C-185
Fri Jan 21, 2022 11:37 am
WENTWORTH AIRCRAFT may have some.
http://www.wentworthaircraft.com I picked 15 or so for my IA several years back. DENNY
DENNY offline
773
DENNY
