Backcountry Pilot • 185 rear seats
185 rear seats
53 postsPage 3 of 31, 2, 3
Re: 185 rear seats
Fantastic job, really like the baggage area tie down rails and led lights!!!
Skalywag offline
Re: 185 rear seats
Do you have a Mfg name / Model number for those map lights? Your plane looks fantastic!
Rod
Wa180 offline
FindMeSpot URL: https://us0-share.inreach.garmin.com/Fattyreflyer
Aircraft: SkyWagon 180E
SkyHawk 172K
Re: 185 rear seats
Wa180 wrote:Do you have a Mfg name / Model number for those map lights? Your plane looks fantastic!
Rod
Checking with Ace.
Sent from my iPad using Tapatalk Pro
G2Gorder offline
Seattle float pilot
Re: 185 rear seats
G2, Great looking mods, should be a real sweetheart to operate. Thanks for installing those gear mirrors. I firmly believe that mirrors, and regular use of them, provides the best available insurance from a landing with gear in an inappropriate position.
Congratulations on making a great airplane even better.
Re: 185 rear seats
Rod
http://m.aircraftspruce.com/pages/el/ledlighting_cockpit/754cockpitlights.php
Prosaria offline
Re: 185 rear seats
Thanks, Prosaria. Here is another place to look: https://www.pilotlights.net/micro-pivot ... ons-1-watt
G2Gorder offline
Seattle float pilot
Re: 185 rear seats
MTV - the mirrors are great. No question about gear position. One on each wing allows the pilot to check gear on both sides.
G2Gorder offline
Seattle float pilot
Re: 185 rear seats
Pinecone wrote:...The location of your electronic ignition is where my firewall mounted battery lives now. I wonder if I've lost the option of electronic ignition now, or if there are mounting location options.
The install doesn't call out for any explicit location, so you are still good if you wanted to go that route. For Goose's 185, I'm installing the block on the top center of the firewall. This is a a bit better location as it doesn't preclude the install of the FA bat box. I also have lots of real estate due to the fact that the vac pump is now gone... There is also room for the block under the FA box if needed. Of course w/ a 24v late model 185 it gets a bit more tricky...
RE: the new gizmos... Looks awesome! Congrats! =D>
www.avthreads.com
Re: 185 rear seats
Dang, there’s a lot of good ideas on that website!
Thanks, and Happy New Year!
Rod
Wa180 offline
SkyHawk 172K
Re: 185 rear seats
I got a PM question that I didn’t see. For some reason, private messages don’t come through on TapaTalk on my iPad. Who knew?
In any event, the question was the part number for the rocker switches from the TTx that I had installed on the panel in my 185. The number is 7R0063. Sorry about the delayed response (about a year delay!).
Greg
G2Gorder offline
Seattle float pilot
Re: 185 rear seats
G2Gorder wrote:I got a PM question that I didn’t see. For some reason, private messages don’t come through on TapaTalk on my iPad. Who knew?
Greg
Are those the row of on/off rockers on your panel? Where did you get them? I tried that PN on spruce and nothing came up, but I'm sure interested.
David
Re: 185 rear seats
I got them through Ace Aviation in Renton, Washington. Ace has been doing the work. They confirmed the part number for the two-pole on/off rockers as 7R0063. There is also one switch that is a three-way switch that I use for taxi lights (narrow beam in cowl on) and pulse lights (recognition pulsing of wing lights and cowl lights). The center position is OFF and the other two positions (up and down) are for taxi/pulsing. That part number is 7R0066. I searched Google for Cessna part number 7R0063 and came up with a number of hits, including https://www.cessnaparts.com/?s1=7r0063& ... arch+Parts
So, it looks as though you should be able to order them directly or through an avionics shop.
Again, sorry for the long delay in responding.
G2Gorder offline
Seattle float pilot
Re: 185 rear seats
Thanks for responding! I have the same Tapatalk issue and never thought about it.
Prosaria offline
