"The left wing sits low in the hangar"
Does your hangar floor slant, or is it level and the plane is tilted?
If the plane is tilted then you should check your tires and landing gear. The 100 series service manual has the procedure.
C180_guy wrote:I leave mine in the OFF position
slowmover wrote: I try to eliminate single points of failure in all my flying. The fuel selector in a Cessna is one of those things I almost never move. Even the most diligent pilot makes a mistake or misses a checklist item occasionally, and it seems super easy to forget to move it out of the OFF position before takeoff. Then the engine quits just after you takeoff. Seconds from disaster at that point.
