Backcountry Pilot • 1966 CE-182 Elevator
5 postsPage 1 of 1
So my friends have one. I’m not super knowledgeable about them, I flew a 182 a little bit in 1995. That was it. This one requires more force to operate the elevator than any other Cessna or Piper I’ve ever flown including twins. It’s almost like you need feet on the panel to pull the handles when it’s static on the ground. We lubed the controls forward of the panel, which did offer some relief. I don’t think anything has lubed since ‘66 when it rolled off the line. So I’m sure that will also help. But are we missing something? The current I/A has gone into the maintenance manual and checked everything. Seems to be put together correctly. Is this the nature of the beast or are we missing something big? The owner has had it about 10 years now and is obviously quite oblivious considering the maintenance it’s been receiving. However he has stated that it’s always been real heavy on the elevator.
gbflyer offline
Re: 1966 CE-182 Elevator
You may have stuck pulleys in the aft fuselage I have not worked on this model but I think the elevators hinge points have bushings which in other aircraft I have seen stuck. Have seen all the above over the years. Maybe someone experienced with this model will offer better advice.
bush master offline
Yes I agree, check the bushings in the elevator hinge points.
Thanks.
gbflyer offline
My 1967 model K has two fairly stout elevator down springs mounted inside the aft bulkhead on each side of the elevator bell crank, making the elevator very heavy as described. If not trimmed properly for takeoff it could be a handful.
On The Fly offline
Aircraft: C`182K
5 postsPage 1 of 1
