hotrod180 wrote:Cary wrote:....One thing to be aware of, for a potential buyer who might like short field capability. The usual "barn door" flaps of Cessnas is not what is on later 210s. They offer plenty of drag, but not a whole lot of extra lift (except maybe the Robertson-equipped versions, but there aren't many of those). So approach speeds are a little higher than they might be if they had the semi-Fowler flaps that most high-winged Cessnas are equipped with......
Just what sort of flaps do they have?
Maybe you can elaborate or post a pic.
My buddy's early 210 has barn door flaps, I believe they're the same dimensions as those on my 53 C180.
I don't think I've ever seen a post-1951 piston powered Cessna single that didn't have barndoors.
I do seem to recall that either the 206 or the 210 is configured a bit differently than the others--
I think with longer-span flaps and shorter span (but maybe deeper chord?) ailerons.
The later cantilever wing had flaps and ailerons more like the Cardinal: Very long, narrow chord flaps accompanied by short(er) span but deep chord ailerons. I only flew the strutted "omni-vision" 210 but I've always loved the later 210. Somewhere along the line I have been told that the wings of the early razor back 210 were straight off a 182 but I've never checked wikipedia to see if that's true (can't say it keeps me up at night).
As for rough field operations I did it quite commonly in a 182RG (rough being subjective of course). Then I was told they make terrible rough field planes because the mains were flimsy.
I found the performance in and out of less than ideal airports to be excellent, but I did happen to look at a main gear leg on take off one afternoon and can see why some people think it shouldn't look so blurry.
