26" Goodyear STC
I have had my FBO owner ask the local FSDO about putting the Goodyear 26" tires on my C180C and his answer both times was, 6 bolt wheels. Even with MTNWEST's 337 from Colorado less than a year ago showing 3 bolt wheels.
SkywagonFloater offline
37
hotrod180 wrote:gbflyer wrote:About 20-1/2" high with the s7 sitting on them at 12psi. You can get a gasket to run between the wheel halves for Matco and go tubeless if you want as I understand it. We are running 7.00 tubes.
I can see the attraction for running tubeless if possible- no ripping the valve stem out if/when the tire spins on the wheel. But I'm curious why you would run 700 tubes with an 850 tire?
Cause they are much lighter and way cheaper than 8.50 tubes, especially when you have a set of one and not the other.
I love EAB!
gbflyer offline
2317
Battson wrote:gbflyer wrote:About 20-1/2" high with the s7 sitting on them at 12psi. You can get a gasket to run between the wheel halves for Matco and go tubeless if you want as I understand it. We are running 7.00 tubes.
Are Matco wheels already tapped for a tubeless valve, or do you make that modification yourself?
You know, I don't know, that is a good question. Call George and ask him. The dude is a rock star in my book!
gbflyer offline
2317
Thu Dec 28, 2017 10:30 am
Hey everyone,
I'm resurrecting this thread because it is close on subject matter for my question. I'm looking at doing a field approval for 26" Goodyear blimp tires for my 205. I currently have a friend that is running them without approval, so I know it works. 29" are allowed via a few STCs and brake and wheel changes. But I'd like to get the 26" approved to avoid having the do those changes.
So my question is, what wheel is approved for the 26" Goodyear blimp tire? I've been doing some digging but not finding a list of wheels that are approved.
Thanks!
GSP
3536
- FindMeSpot URL: https://share.garmin.com/WolfAdventures
- Aircraft: Cessna 205
Thu Dec 28, 2017 10:38 am
6” 3 bolt on my 185 and no problem getting a FA.
Barnstormer offline
2700
- Aircraft: C185
Thu Dec 28, 2017 10:43 am
Thanks Phil. I’m seeing there are a few FA on here in another thread but some links aren’t working. You by chance have a digital copy you could send me do you?
3536
Thu Dec 28, 2017 11:06 am
Grassstrippilot wrote:Thanks Phil. I’m seeing there are a few FA on here in another thread but some links aren’t working. You by chance have a digital copy you could send me do you?
Will do, probably tomorrow as I’m headed back home today.
Barnstormer offline
2700
- Aircraft: C185
I assume the Field approval paperwork would be similar for the lighter Cessna 172. If anyone has this paperwork I would love to have it so I can get them installed on my 172.
[email protected]
JOhn_Hayden offline
1
