UtahMaule wrote:Long 2 blade.
3 are for looks. And extra weight, more expense, and less performance.
UtahMaule wrote:No. IO-540. But that's even more reason for 2 blades. Plenty of O-360 guys have done this testing for you. Hands down 2. Of course maybe you like the look. Hate money and want a heavier nose.....[emoji848]
UtahMaule wrote:Yeah. I flew both. 11ZA is RWM's badass mosheen. He can tell more. I was always in the 2 blade camp. Even more now. I flew both, same plane, same day. Hands down 2 won. I know Kevin loves his 3. But he only tested 3 blades against each other. Bill Duncan tried a 4 blade on his beast. He's back to 2. I've been flying a 300 horse CallAir. 2 blades. All the scout and husky guys have thrown rocks at the 3 blades. Less is more. Trust me.
Rob wrote:UtahMaule wrote:Yeah. I flew both. 11ZA is RWM's badass mosheen. He can tell more. I was always in the 2 blade camp. Even more now. I flew both, same plane, same day. Hands down 2 won. I know Kevin loves his 3. But he only tested 3 blades against each other. Bill Duncan tried a 4 blade on his beast. He's back to 2. I've been flying a 300 horse CallAir. 2 blades. All the scout and husky guys have thrown rocks at the 3 blades. Less is more. Trust me.
Be careful with generalizations.... If we are looking at pure physics, then one blade should be the absolute best. But in the real world everything comes at a compromise. Kevin may have only tested various three blades, but I can assure you having owned multiple MT's (both 2 and 3 bladed), they don't make a two blade that has enough blade for our (Kevin and my) combination. I ran these props back to back multiple times. George Mandes did this exact exercise with the exact same results. I will say that on this combination you can extract the same (or very close) performance out of a two blade C66, but it takes at least a 86" (3 inches longer) prop to do it.
Look at it this way, several (but not all) of the MT STC's that cover both 2 and 3 blade variants utilize the exact same blade on either hub. The only physical way for the 3 blade to produce less thrust under that circumstance is for the engine to not be able to produce enough horsepower to effectively turn the 3 blade prop. Period. When we were trying to decide between the 2 and 3 blade MT for our application, flight resource indicated that 300 hp would be the minimum horse power needed to effectively turn the bigger prop, which in our case should have been borderline, so the only choice we had was to really either guess, or try them both out (which we did).
The Mac 401 smokes the Mac 2 blades (any flavor) out of the hole, the reason many back country guys poo-poo the big 401 prop is simply the weight (more the cg effect than actual pounds). I *think* that if you could get a longer MT, it would work for our application, but that's just pure speculation...
The fact that you Callair works best with a 2 blade is as anecdotal of any of this. Ever see any working turbine AT or Thrush with a two blade on it?![]()
In fact on that note, all the 500 gallon -34 powered guys are going from 3 blade to 4
We have already converted two of our airplane, and there is no comparison, it takes a crippled combination, and turns it into a pocket rocket. In most cases it's proved a 10% increase in hauling ability, in my admittedly piggish combination it makes almost 1,000# hauling difference
But again that has little to no bearing on what might work best on an O-360 powered M4.
I personally don't care for the looks of any MT, but my mission dictated a better hole shot than I could get out of the shorter C66s, but not at the weight penalty of the 401's. So for me the best compromise was a 3 blade MT. Believe me when I say, I really wanted the lighter more economical 2 blade to work, but the truth is, it just left too much horsepower lying on the table. There is only one reason to build more horsepower into your airplane, and that is to be able to turn more prop.
Also as I alluded to RWM when we spoke about this, I have had conflicting results running the same two props on two different physically airframe/engine combinations even when they are the same model. We see this all the time in our work fleet, as we have multiple props in the mix to keep from having an airplane down while a prop needs service. Some engines are peppier (which affects it's ability to turn the bigger prop), some airframes are draggier, it all adds up.
Lastly, I would have to say apples to apples is going to be the best barometer you're going to get short of actually running them on your own airplane. It's the only advice I could afford RWM, because as I said to him, I had no IO540 / Maule experience... Consequently just looking for O-360 / MT combinations will still leave some wiggle room when trying to nail down whats best. You really need to poll O-360/MT/Maule M4 owners... and even that's not 100%, but probably as close as your going to get short of running them yourself...
Take care, Rob
Coincidentally the 2 blade Husky / Scout MT's are using the same blade they use for C180-/185's.
DeltaRomeo wrote:Pitching for pro's and con's of a 3 blade conversion for a 180hp O-360. ....
