337 /FAA
If you had a job done and the 337 for VG's was misplaced lost how can you get a copy from the FAA?
Green Hornet offline
527
AKA SOJORRN
1997 Maule-M7-235C
I am a leaf on the wind watch how I soar! Hoban "Wash" Washburne, Firefly/Serenity
WOC SPOT
Go here:
http://aircraft.faa.gov/e.gov/ND/They will send you a CD with all the records they have for that aircraft. If the 337 was properly submitted and approved, it will show up there. I assume that you can just print a copy of that for your logs and you're good to go, but I have been wrong before.
gb
gbflyer offline
2317
gbflyer wrote:Go here:
gb
jm,
Thanks it will be interesting to see what I get back.
Bill
527
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
Dont get in a hurry the last two I did took 3 months to get the CD
mr scout offline
774
mr scout wrote:Dont get in a hurry the last two I did took 3 months to get the CD
OUCH!
527
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
Ummm VG's are STC'd on the Maule .... more to the story I'm sure
Hottshot offline
710
Hottshot wrote:Ummm VG's are STC'd on the Maule .... more to the story I'm sure
You file the 337 from the STC after you install the VG's.
Bonanza Man offline
909
Micro Aero Dynamics holds the STC for the Maule and it is for the particular Maule so the installer needs to have an airplane to work on in order to order a set of VG's. That is what I was told by Johann. I have the STC but somewhere allong the line I lost the 337.
527
AKA SOJORRN
1997 Maule-M7-235C
WOC SPOT
