360 camera mounting
Discuss cameras, lenses, techniques for shooting and post-processing. Please do
not ask questions about how to post photos in the forum. See the
Help section for website usage questions.
The further in front the more it looks like you are following a drone. I like the lens more forward than the prop.
I have a telescoping carbon fiber pole that actually allows for the power cable to be threaded inside the pole. Yes I use a power cord as I hate batteries running out at the moment of the money shot.
I wired my wings with a power box in the wing wired to the airplanes power and a switch on the panel to turn the power on and off. Running action cams sans battery helps to have them not overheat which is a common complaint among the masses.
Hope that helps
Note: The telescoping pole I have is no longer available last I saw, but there should be plenty out there if you search.
Utah-Jay offline
364
- Aircraft: Bearhawk Companion
