Some change I made recently invalidated old cookies and causes many forum topics to generate 404 errors. It seems that the fix is to once again delete your backcountrypilot.org cookies. If you can't selectively delete them, just delete all cookies. Clear your cache for good measure.
Then login. The issue appears to be for users who have never logged in after clearing cookies.
The site is running much faster than it has since launch, so if it seems otherwise, try this simple action of deleting cookies and clearing cache, then login. It's ok if you logout afterward, you just have to login successfully once.
If you talk to other BCP users outside the forum, pass this tip on. It's a bug and will get fixes soon, but this is a temp solution.
