Sun Feb 04, 2007 11:07 am
Zero one victor,
This process started well over ten or fifteen years ago. The North Slope Borough of Alaska was selected to evaluate a newer, more efficient emergency beacon type-an EPIRB.
During the ten year evaluation period up there, the number of "saves" due strictly to these beacons was amazing.
Before you critisize this move, you need to first understand what a "good deal" you have with a 121.5 beacon.
Let's say you crash, and your 121.5 beacon activates. If you're lucky, one of the SAR/SAT or COSPAS satellites is overhead, but you could sit there for up to an hour or so, waiting for a satellite to pass overhead and reflect your ELT signal to the Rescue Coordination Center (RCC). RCC logs the ELT hit, but does precisely NOTHING with it, due to the fact that 121.5 signals are all the same, and the false alarm rate is high. Besides, the first hit tells them the location of the ELT within a few hundred miles only.
Another hour passes, and the next satellite comes over the horizon (if you're lucky, you may be in an area where they pass every 40 minutes or so--north is better). Now, RCC has both a slightly better location by triangulation as well as the notion that maybe this is a real accident. They notify whoever is responsible for search and rescue in that area to start an ELT search. So, the CAP drives around airports in the area and listens for ELTs. Aircraft in the area are asked to monitor 121.5, etc.
Another hour passes. Now, with the third satellite pass, RCC can tell that the signal (based on triangulation) is in a fairly confined area, and not located at an airport. Now, they launch the SAR resources.
In general, they'll be there anywhere from four to five hours post crash, if you're lucky.
Now--the 406 deal:
You crash. Your 406 beacon activates. Maybe an hour passes, and the signal reflects from a satellite to RCC. RCC decodes the digital signal, which has a discrete code on it, and they look it up in their database. When you bought the thing, you registered it with RCC. RCC calls your contact phone numbers. Your wife answers the phone, and when RCC asks to speak to you, she tells them that you are flying. RCC is now on high alert, and initiates the SAR process. If you are on a flight plan, they will initiate SAR along your proposed route (you don't deviate from your planned route often do you?). In the meantime, rescue forces in the general vicinity of the first hit are put on alert status. That means a Pave Hawk helicopter in many parts of the world, Coast Guard Jayhawk, etc.
They get the second hit, and triangulation narrows the location, and they launch the Pave Hawk, with an KC-130 tanker for support. They proceed to the general area. They are on site by the time the third hit comes in, and this gives them a nearly precise location. The PJ's winch down and save your narrow ass.
Now, if you bought the "extra cost option" GPS connectivity for your new 406 beacon, on the very first hit, RCC would not only know precisely who you are, but also precisely where you are. Rescue forces would then be launched immediately.
On the North SLope, they used a very sophisticated all weather capable helicopter, and they saved a lot of those folks lives who would never have otherwise survived, like folks who got out on a chunk of ice which broke loose from shore while they were hunting.
The 406 units will come down in price. Right now, there is only one unit on the market for little airplanes. There are a bunch of handheld units available, and they are a great device if you hike the backcountry, etc. as well.
Few people realize how long it takes for ANYTHING to happen after the activation of a 121.5 beacon. I do. I like the 406 concept.
The new 406 aircraft beacons come with 121.5 transmitter as well, so other aircraft will still be able to hear them.
DF'ing a UHF signal is not the best, so searchers will also still use the 121.5 signal for DF work, probably.
I'm not rushing out to buy a 406 beacon right away for the plane, because the prices will come down soon, I believe. But, it would only take one little oops and I'd sure wish I'd dropped the coin sooner.
