5" wheels bigger tires
Is there any way to mount bigger tires on 5" Cleveland wheels? I don't want to change axles, brakes etc.
If not, Is there a way to put bigger wheels on the 1-1/4" axle & Cleveland rotor & pads? This is going on a flying CH701.
lqbanotxano offline
2
- Aircraft: Zenith CH 701
Check on the VansAirForce website. A lot of RV drivers have put larger 380-150 x 5 tires on their RVs. These are a bit bigger than the normal tires, but not a whole lot, and they do fit on the original cleveland wheels. On my RV-9 I have slightly longer axles (by an inch) and put some Matco 6" wheels with 800-6 tires. Matco has wheels that will fit a 1.25" axle that the RVs use and they are considerably less expensive than the clevelands.
Greg
GregA offline
149
- Aircraft: RV9
+1 on both of Greg's recommendations.
Mister701 offline
2134
- Aircraft: Rans S7LS
Thanks Greg,
I already have the 380-150X5 on. I will look into the Matco wheels.
lqbanotxano offline
2
Don't know if he has anything for you, but Robbie Grove seems to produce some nice wheel and brake stuff.
10534
+1 on Grove's stuff. I am biased because he's a personal friend, but regardless of that his design and manufacturing quality is exceptional. Truly an innovator.
2226
GregA wrote: A lot of RV drivers have put larger 380-150 x 5 tires on their RVs. These are a bit bigger than the normal tires, but not a whole lot, and they do fit on the original cleveland wheels.
Greg
Do you know how tall the 380-150 x 5's are?
SkySteve offline
258
- FindMeSpot URL: http://share.findmespot.com/shared/face ... ognaNo67qS
- Aircraft: Kitfox
SkySteve wrote:GregA wrote: A lot of RV drivers have put larger 380-150 x 5 tires on their RVs. These are a bit bigger than the normal tires, but not a whole lot, and they do fit on the original cleveland wheels.
Greg
No, I don't know exact measurements, but they still fit within the wheel pants on most RVs, so not a lot bigger than the standard tires. Here's a link to a fellow in CO who changed them out, with a photo for comparison. He says about 1" additional diameter. I know several folks who have put them in without any changes to the fairings, but it will depend on how the fairings were originally built.
http://mesawood.info/myrv7a/building/la ... s_main.htmGreg
GregA offline
149
- Aircraft: RV9
If it was me, I'd just bite the bullet and buy a set of 6" wheels.
There's a whole world of 6" tires choices large and small.
Matco sells wheels but from the little I've seen I'd prefer Groves.
10534
GregA wrote:SkySteve wrote:GregA wrote: A lot of RV drivers have put larger 380-150 x 5 tires on their RVs. These are a bit bigger than the normal tires, but not a whole lot, and they do fit on the original cleveland wheels.
Greg
Thanks, Greg, for the info and link. I've got 8.00x6's on my Kitfox mains and want to put something larger than the standard 5.00x5 on the nose. I've been thinking of a 6.00x6 on the nose but will need to modify the nose gear to do it (an easy mod). The 38--150x5 doesn't look like it will help much. I also have Grove wheels/brakes on the mains and they are great.
SkySteve offline
258
- Aircraft: Kitfox
Fri May 06, 2016 10:17 am
FWIW someone just posted a set of NOS Cleveland 40-75 wheels and brake discs on the Marketplace forum for $600. I haven't priced wheels lately but that looks like a pretty good price to me.
10534
