Mon Feb 26, 2018 11:51 am
The tailwheel tire is the Rodney Dangerfield of aircraft parts.....it don't get no respect.
A routine check of tailwheel tire pressure is a good habit to get into. On main wheel tires, it's usually fairly easy to see a REALLY low tire during a routine pre flight. But, many tailwheel tires look about the same with 50 psi in them as they do with 5 psi in them. Right up till you put a little extra weight on them, that is.....or turn by breaking the tailwheel loose, and pivoting around. That's usually when you discover a flat tailwheel tire, though there probably was nothing wrong with it except inflation pressure prior to that "event".
I know I've checked tailwheel tire pressure several times, looked at the gauge and thought "shoot, dang gauge is screwed up....only reads 5 psi.", only to try it again, and again, and finally realize that the tire really does have only 5 psi. The contortions you sometimes have to go through to get a gauge on those tailwheel inner tube valve stems doesn't help, either..
Check em regularly, keep the pressure up, and they'll do fine for many, many hours.
