Backcountry Pilot • 7.00 vs. 8.00 tire radius?
6 postsPage 1 of 1
BLUF: what is the radius of installed 7.00 and 8.00 tires?
I'm finally getting around to changing the Nose wheel tire on my 206, normalizing the attitude with the airglas STC change. The attitude with the nose serviced correctly and about a mid-chart, heavy load is getting me snickered at when I taxi by. I'm not using the airplane for the rougher stuff that I'd hoped for.
I'm deciding between a 7.00 and 8.00 x 6. I know the numbers vary, but what is the general radius of 7.00 and 8.00 tires installed so I can do some experimenting with attitude?
Brett
moppready offline
Re: 7.00 vs. 8.00 tire radius?
Goodyear had tire dimensions on line.
I used it for determining how big a tire would fit in a Stinson wheelpant.
Dave
d.grimm offline
The new Aero Classic 800x6 smoothies are advertised as 21".
Their 850x6 smoothies are 22".
hotrod180 wrote:The new Aero Classic 800x6 smoothies are advertised as 21".
Those are diameters but depending on how you run them you'll loose an inch or two or more on height loaded. Something to consider if you're that sensitive. Some tires really flatten out, others a lot less so.
TruckTent offline
Aircraft: PA20
Brett,
I don't have radius of those tires. But, I found that the 8.00 nose tire combined with the 8.50 on the mains resulted in the best angle on the ground, and closest to stock 206 angle. Easier to land without concern for wheelbarrowing.
Also, bear in mind that different brands of tires sometimes have different radius, even though they're listed as same size by spec.
Brett,
6 postsPage 1 of 1
