Backcountry Pilot • 8.0 tires on Cleveland wheels and brakes?
14 postsPage 1 of 1
I had the brakes changed to the Cleveland brakes & 8.5 x 10 tires with Cleveland wheels. Will my orig 8.0 x 6 tires and wheels work with those brakes? I orig had McCullough brakes on the plane.
If not what needs to be done to make them work,
thanks
RocketRick offline
Re: 8.0 tires on Cleveland wheels and brakes?
On what type aircraft?
L-19 offline
<<On what type aircraft?>>
C180B
RocketRick offline
RocketRick wrote:I had the brakes changed to the Cleveland brakes & 8.5 x 10 tires with Cleveland wheels. Will my orig 8.0 x 6 tires and wheels work with those brakes? I orig had McCullough brakes on the plane.
thanks
Am I missing something on this thread :?: Is like an incomplete sentence :|
Glidergeek offline
Aircraft: 1968 P206C
DG 400
I would assume your Clevelands will work just fine with the six inch wheel and the ten inch wheel.
Though... What brand are your original wheels? :shock:
thanks
Hey cut him some slack it's his first post :D
L-19 offline
GumpAir wrote:I would assume your Clevelands will work just fine with the six inch wheel and the ten inch wheel.
I recently had Cleveland dble puck brakes and 8.5 x 10 tires on Cleveland wheels installed on the 180B.
Before the change over, the tires were 8.0 x 6 with McCullough brakes.See pic.
RocketRick offline
thanks
Right o my very first post. =D>
RocketRick offline
It seems you may be mixing your metaphors, so to speak.
What WHEELS are you using? Tires are noted by tire size X wheel diameter (for example 8.50 X 6 implies an 8.50 size tire that fits a six inch WHEEL rim.
far as I know, the only way to (legally) adapt 10 inch wheels to a 180 is to either use the stock 6 inch wheels and 10 inch wheel adapters from Gar Aero (now some other name, but wheel adapters in any case) OR use Alaskan Bushwheels' 10 inch wheels. Those would be the legal (as far as I know) way to adapt 8.50 x 10 inch tires to a 180.
So, what WHEELS did you use, pictures of the NEW setup would be helpful.
What he is asking, is if he can run his 6" wheels and disks with the small tires (presumably for cross country speed) while leaving the Cleveland calipers in place.
I also assume the legal answer is no :( , most likely the next best solution is to watch for a used set of Cleveland wheels to mount your smaller tires on, and yes I know you just bought the Gars...
I will shoot you a PM with a local guys contact info, who may be able to help you.
Take care, Rob
Rob offline
mtv wrote:It seems you may be mixing your metaphors, so to speak.
I said in my post;
Don't you understand the words coming out my mouth Ha!.
Never mind,....I'll figure it out ok.
Thanks for the PM Rob... :)
Good luck All.
RR
RocketRick offline
[-o< :?: WTF :?:
iceman offline
What Rob said!
First of all, welcome!
I don't think you want to run the original McCauley wheels with your updated Cleveland brakes if that is what you are asking. I doubt you'll want to switch back to 8.00's anyway, unless of course you are going on skis.
gb
gbflyer offline
Tanks gbflyer - whats funny is the AP/AI that installed the Cleveland brakes and the 8.5 x 10 tires etc
wasn't sure if I cld do it or not. He said he'd hafta put them on and SEE if they wld work. At least he was willing to explore the idea.
Fly safe.. :)
RR
RocketRick offline
14 postsPage 1 of 1
