ADS-B Compliance
I’ll admit, I don’t know much about ADS-B compliance yet, but the main thing I’d like to understand more is the cost.
Approximately how much can I expect to spend to make a Cessna 182 (56-59 model) ADS-B compliant if I found a plane that isn’t compliant?
Thanks
58Skylane on Tue Dec 17, 2019 9:52 pm, edited 1 time in total.
5297
uAvionix TailBeacon is about $1995 and pretty quick to install if you do have a working Mode-C transponder.
akaviator offline
512
- Aircraft: Cessna 180
I got a Garmin GTX 335 with harness, new coax and transponder antenna for just under $4k. Installed myself. Easy install.
‘68 182L
AK737Pilot offline
50
- Aircraft: Cessna 182L
Thank you. These numbers are good to know while I consider an aircraft for sale without ADS-B.
5297
58Skylane wrote:Thank you. These numbers are good to know while I consider an aircraft for sale without ADS-B.
The other question you need to ask yourself is whether you actually NEED ADS-B equipage. If you never need to go to A,B or C airspace, or higher than 10, 000 feet while greater than 2500 feet from dirt, you may not need it.
10515
In round numbers: $2000 for uAvionix, a little more for the Garmin in-line thing, $5000 for transponder or panel-mounted UAT, $7000? for the Lynx.
If you have an old transponder, talk with the avionics shop about whether the uAvionics or Garmin in-line thing will burn it up. AIUI, they’re intended for digital transponders.
StuBob offline
293
- Aircraft: Cessna 185 Skywagon
Don't forget to add in the labor for the Uavionix. I threw in a tailbeacon in my 56, the screws and mounting on the stinger were different and an additional ground was installed for solid electrical current, added a few hundred bux above the $2000 shown here.
Joewcasey offline
68
mtv wrote:58Skylane wrote:Thank you. These numbers are good to know while I consider an aircraft for sale without ADS-B.
I thought about that. I’m sure most of my flying will be outside those airspace’s but I’ll probably end up wanting to go into Billings, Boise, Salt Lake area and even Southern California area once in a while.
Ideally I’d like to find a plane already equipped with ADS-B. Looks like the cost of these ADS-B units can range from $2k to $4k+. If I find a plane I like and it doesn’t have ADS-B, depending on budget at the time I’ll probably just go the cheapest route. But for now, I just wanted to see what most are spending on these units including install.
5297
My experience goes back to the transponder requirement, but if you go low they don't know, or care.
4972
Wed Dec 18, 2019 12:35 pm
You also need to be aware that by complying, you will be tracked by the gummit even in anonymous mode, which turns out isn't. In addition, you have just voluntarily given them the hooks for automatically levying user fees, to say nothing about automatic code enforcement. RESIST!
C180_guy offline
488
“If you never need to go to A,B or C airspace, or higher than 10, 000 feet“
I’m thinking class D airspace too?
Glidergeek offline
1937
- Aircraft: 1968 P206C
DG 400
C180_guy wrote:You also need to be aware that by complying, you will be tracked by the gummit even in anonymous mode, which turns out isn't. In addition, you have just voluntarily given them the hooks for automatically levying user fees, to say nothing about automatic code enforcement. RESIST!
Is this actually happening?
ZPilot offline
286
- Aircraft: Lake Amphibian
The GDL-82 is more labor to install but is the only certified solution I know of that is actually anonymous in a certified airplane. I would expect to be into it $2500 before it's done.
akschu offline
439
- Aircraft: 1949 C-170
20?? 4 place Bearhawk
ADS-B is not required in class D airspace. It is required only in airspace where transponders were previously required, so A, E above 10K (except in Alaska or within 2,500 feet of rocks), C, B, and mode C veil around B.
Troy Hamon offline
913
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 04iX0FXjV2
- Aircraft: Piper PA-22
And if that's not enough to think about if you are flying thru Canada, and once they have mandated ADS-B country wide, unless I'm mistaken (and if I am I'm sure A1skinner or one of my other Canadian friends will correct me) you'll find you need a 1090 MHz unit (more expensive and no anonymous mode) and not a 978 MHz (cheaper and with an anonymous mode) unit.
Mexico or the Bahamas might be the same way, I'm sure those that fly there will chime in.
Sucks for sure. Especially since it's from the same government agency that allowed the 737 Max to continue flying when they knew more crashes were coming- follow the money I guess.
Barnstormer offline
2700
- Aircraft: C185
Is no electrical system and never had one still legal with a phone call to D and light gun?
4972
Barnstormer wrote:Mexico or the Bahamas might be the same way, I'm sure those that fly there will chime in
Correct. Mexico requires 1090 beginning Jan 1.
rw2 offline
1799
- FindMeSpot URL: https://share.delorme.com/LaNaranjaDanzante
- Aircraft: Experimental Maule
contactflying wrote:Is no electrical system and never had one still legal with a phone call to D and light gun?
Yep, know a few folks that do this to get in and out of D airspace when needed.
Troy Hamon offline
913
Thanks Troy. Good to hear.
4972
