29singlespeed wrote:You are correct, I mis-typed IN meaning out and have changed the subject. Weight / Space are not an issue. I will look into the Appareo. Stratus and Garmin were on the list but had not found Appareo in my search. The aircraft is an M5 with a basic 1 radio set up - so basically a blank slate.
A1Skinner wrote:The new tailbeacon X has a built in mode S transponder that is controlled by an AV-30. It is built with diversity so it works in all countries that are running sat based ADS-B. I'm thinking its a sweet way to go as it doesn't require a transponder in the panel, just an AV-30 which is a sweet unit on its own.
No I'm not sure on that part yet. I'm hoping it's fairly straight forward though. I know changing the baro and DG is super simple, so hopefully along the same lines. I do think its a very slick package, I plan to put it in my 206 once I save up some.29singlespeed wrote:A1Skinner wrote:The new tailbeacon X has a built in mode S transponder that is controlled by an AV-30. It is built with diversity so it works in all countries that are running sat based ADS-B. I'm thinking its a sweet way to go as it doesn't require a transponder in the panel, just an AV-30 which is a sweet unit on its own.
Interesting. If I get this prospective plane I was going to add the AV-30 as it currently has no attitude indicator. I just looked it up and thats a pretty slick bundle. https://uavionix.com/product/tailbeacon ... -c-bundle/
I looked but I didnt see how the interface worked to change sqwak code. Any ideas?
IL_170A wrote:You mention a blank slate and a need for an attitude indicator. This might not be in your budget, but I'd recommend the Garmin GNX 375 which is a combination GPS and ADSB In and Out transponder all in one. Pair that with a G5 (or two) and you'll gain a ton of capability.
29singlespeed wrote:IL_170A wrote:You mention a blank slate and a need for an attitude indicator. This might not be in your budget, but I'd recommend the Garmin GNX 375 which is a combination GPS and ADSB In and Out transponder all in one. Pair that with a G5 (or two) and you'll gain a ton of capability.
It's not at this time. I have looked at the GNX 375 but am partial to the AV-30 because of the form factor. Likely will do the Av-30 with the Tailbeacon X -- it's about $4100 but appears from the maule forum some have had trouble fitting the tailbeacon in the tail light slot. So we will see.
All this said might be running into a hurdle getting hangar space here in Gunnison, CO so that might halt everything. Not a place I want a plane outside.
