i was thinking that those involved would have to have the same purposeFlyhound wrote:I was in 3 different partnerships before I bought the Maule by myself. All were good experiences even though the aircraft were very different. One was a Grumman AA5A Traveler, one was a Pitts S2A, and the last was for a 182 with the Texas Skyways O550 under the cowl. The one thing they all had in common were really good bylaws and clear definitions of what each pilot could expect. The worse thing that can happen is to form a partnership where each partner has different expectations for how the plane will be used and what their rights and responsibilities are. Get that clearly established in the beginning and the rest should be clear sailing.
Cary wrote:As long as it's an equal partnership with the same expectations, it works. When that changes, even if you have it all in writing, things can go downhill. The partnership I was in, starting in the 70s, began with 3 in a low-hour 70 Skylane. We did pretty well, even when one of the partners sold his share and eventually two of us bought out that 3rd share.
But then my pard wanted something faster, so against my better judgment, we bought one of the very first TR182s off the line. Since I couldn't afford half, he offered that it be 1/6-5/6 ownership. That sounds good, but you can see the writing on the wall--he began calling the shots. Then a couple years later he wanted to trade for a new T210, and this time he offered that it be 1/12-11/12. That lasted only a very few months, before it broke down completely. There are some details going into that that aren't necessary to discuss here, but it boiled down to being mostly his airplane, with his decisions governing how I used it--and frankly I didn't need and couldn't effectively use a high speed 6 passenger airplane which wasn't any fun to fly.
So my advice: make sure you keep it equal, that all partners can afford their shares equally, that you all fly similarly with similar qualifications--and get everything in writing. If you use a partnership template (such as AOPA has), don't mimic it slavishly--make sure it is adjusted to fit your situation, and then (and I think this is very important) take it to a knowledgeable lawyer who understands aviation matters to tweak it into final form!
ExperimentalAviator wrote:Cary wrote:As long as it's an equal partnership with the same expectations, it works. When that changes, even if you have it all in writing, things can go downhill. The partnership I was in, starting in the 70s, began with 3 in a low-hour 70 Skylane. We did pretty well, even when one of the partners sold his share and eventually two of us bought out that 3rd share.
Cary, if it got in to numbers that aren't the same as the number ppl in the partnership, it would no longer a partnership.
thanks,
i'm thinking of a equal partnership, everyone to have same equal power over the plane.Cary wrote:ExperimentalAviator wrote:Cary wrote:As long as it's an equal partnership with the same expectations, it works. When that changes, even if you have it all in writing, things can go downhill. The partnership I was in, starting in the 70s, began with 3 in a low-hour 70 Skylane. We did pretty well, even when one of the partners sold his share and eventually two of us bought out that 3rd share.
thanks,
Not true. From a legal standpoint, any partnership can be unequal. All it takes is a statement in the partnership agreement describing the percentage or fractional ownership, and if it's a modification to an existing agreement, then an amendment to the agreement properly executed by all of the partners. From a wisdom standpoint in an airplane ownership partnership, however, my limited experience is that it ought to be avoided.
Any time one partner (or one member of an LLC or one shareholder of a corporation) holds the deciding authority in an airplane ownership arrangement, the potential of misuse of that power is too great, I think--basic human nature. I've counseled quite a number of pilots who were wanting to enter into some multiple-owner relationship to keep the decision-making authority equal, and to make major decisions unanimously.
