I bought a Highlander kit project from a guy in Florida and need to get it here to CA...obviously the sooner the better
The plane is on wheels, tail feathers are installled, wings are of the quickbuild type so they are basically a skeleton with the same dimensions. Most other parts will be packaged inside the fuselage structure for easier moving. No engine, so the weight of the airplane would probably be in the neighborhood of 300 lbs.
The gentleman I bought it from is an older guy, and won't be able to do much in the way of lifting, although there shouldn't be a need for much of that...mostly getting the wings down off the wall (he just had hernia surgery). I might be able to talk him into removing the tail surfaces for a more compact footprint, which might allow room for other freight items.
I put an ad on UShip.com but not getting many hits. As you might imagine, I would prefer an enclosed trailer as I can't be on the other end to prepare things the way I like them for protection from the elements.
I know Sun 'n Fun is coming up in FL, and maybe there's people that are coming back empty or.....
Thanks for any help with this
Aaron
337-489-68 three four
