Aircraft tug options
While your thinking about it, it wouldn't hurt to spend the $300 on a 110v free wheeling winch and mount it in the back of the hangar. I have plenty of other options available to me, however the winch has turned to to be the best choice in all 3 of my hangars.
Ron
On The Fly offline
199
- Aircraft: C`182K
I've had winches in a couple hangars also. If your only concern is pulling the plane into the hangar, they are an amazingly cost effective and easy to use solution.
rw2 offline
1799
- FindMeSpot URL: https://share.delorme.com/LaNaranjaDanzante
- Aircraft: Experimental Maule
Mon Nov 18, 2019 11:33 am
I have a winch on the back wall of the hanger that works great. I made a front tow bar for pulling out plane when on straight skis. I use a polaris explorer 350CC machine with chains year round and it does great at draging planes all over the airport.
DENNY offline
773
DENNY
Mon Nov 18, 2019 11:35 am
DENNY
DENNY offline
773
DENNY
Mon Nov 18, 2019 11:59 am
Okay, here is the TRUE pilot’s solution: Buy a winch and install it in back of the hangar. Then, buy a four wheeler just in case the winch were to fail.....keep the four wheeler at home.
Problems solved!
10515
