Backcountry Pilot • Airwolf Remote oil filter C185
34 posts • Page 2 of 2 • 1, 2
Re: Airwolf Remote oil filter C185
AEROPOD wrote:I've fixed leaks on all of the options as well.
As in, anything you bolt can and likely will leak one day, just less places for it to happen on the TCM adapter.
A1Skinner wrote:
There is less places for the TCM one to leak, but there is still and AD out on it, and I have had them start to leak on multiple planes. It's an easy o-ring to change, but definitely not exempt from leaking either.
I believe the AD just mandates what the mechanic (or owner) should have been checking when they did an oil change anyway, but you're right, there's are AD.
AEROPOD offline
I have a remote oil filter sitting on the shelf. Removed during a motor mount swap this fall. If anyone is interested let me know.
Dahley offline
Aircraft: Looking...C-185
It is checking, and putting a torque wrench on it as well. Not too much different form the AD on the tempest adapter really.
Or torque it once, then put torque putty on it, and just check the torque putty.
AEROPOD offline
I'm over the Tempest. It's hit or miss on whether I'll spend the morning cleaning up oil. Ordered an Airwolf - thinking about lower left side - so send more oil filter porn!
This is now for sale with the new, unused seals. $300.
Ace007 offline
Aircraft: Cessna 180
Tempest filters (used to?) come packaged in individual plastic bags.
They work pretty well to contain the mess if you slip them over the filter after you break the torque.
PM sent.
Damn hotrod, been changing filters for 40+ yrs and that plastic bag is probably the best idea I've heard.
Thank you
flyingjack offline
Aircraft: Husky/T206H
I have a spare Cessna / TCM one if interested.
PNW Flyer offline
Aircraft: C182P
Dahley wrote:I have a remote oil filter sitting on the shelf. Removed during a motor mount swap this fall. If anyone is interested let me know.
An airwolf?
I have installed two of the Airwolf setups on Stinsons, one Franklin and one Lyc, installation was fairly easy and I never had an issue with them. Filter changes were easy and clean with a firewall mount and upright position.
shorton offline
Aircraft: Stinson 108-2
Ace007 wrote:I'm over the Tempest. It's hit or miss on whether I'll spend the morning cleaning up oil. Ordered an Airwolf - thinking about lower left side - so send more oil filter porn!
Installed a number of Airwolf remotes. Never had one leak. On the radial installs, it’s the only item that isn’t leaking :D
TR
Remote filter on 1340 Ag Cat
Airwolf on Beaver
Airwolf on Stearman
TR offline
Aircraft: PA-18A
C-180H
DHC-2
G-164 Ag Cat
Yes I have an airwolf. Sent you a DM.
Dahley offline
An airwolf?
Yes I have an airwolf sent you a DM.
Dahley offline
[quote="PNW Flyer"]I have a spare Cessna / TCM one if interested.
I'm interested. Shoot me a message with a number.
AEROPOD offline
