scottd170 wrote:Coming from "New Hampsha".
denalipilot wrote:Hoping to make Saturday
You do know that the safest place to be on the ground is in the middle of the target?????Planning to compete in the flour bombing.
PilotPeat wrote:I was at Valdez two years ago and got volunteered to help measure the flour bombs. There were some very accurate shots, if I recall right the winning bomb was within 1 1/2 feet of the center of the tarp. They were using small paper bags of flour stapled shut and with a few inches of survey tape with the N number written on it. Something like 1/4 lb, maybe 1/2. Not more than 1 lb for sure. The bombardier in the winning plane was on weekend leave from the air base-his day job? Bombardier, lol.
The sure made quite a noise hitting the ground. I was advised to NOT get hit as it would leave a mark.
AKclimber wrote:For the flour bombings are you allowed to make a sighting tool?
It's a simple vector algebra problem - you have the horizontal (airspeed) and vertical (altitude) component of the triangle and then you just need to calculate the angle of the sight. Drop the flour bomb when the target is in sight.
