Backcountry Pilot • Alaska trip planning 2026
8 posts • Page 1 of 1
Folks may be starting to plan for a trip up North in 2026. A couple of items that are new (at least to me):
* Canada requires a first aid kit be carried in your plane. There are specific required contents listed as well. Make sure simple things (e.g. alcohol swabs) are not expired!
* Canada is requiring aircraft to have a HALON fire extinguisher on board too. And, make sure it isn't expired!
Rumor has it that ramp checks may be more prevalent this year...
Links to the above first aid kit and HALON requirements (https://fly2ak.com/canada/)
tedwaltman offline
Re: Alaska trip planning 2026
Hmm, we fly through US airspace all the time (departing in Canada, landing in Canada) without a flight plan. The reference on first aid kits and fire extinguishers is under CARS 705 (like FAA part 121). I didn’t see it for the equivalent of Part 91.
I’ll dig into it a little further. Might just be a rogue customs zealot.
SOR/96-433 is referenced. Here is who it applies to (doesn’t seem to be US GA).
Karmutzen offline
Thank you for digging into the first aid kit and fire extinguisher requirement.
I believe a flight plan is always required for any over-flight. I’d sure encourage folks to err on the side of extra caution and file one, especially in light of current events. In other words, don’t poke the bear even though it may look like it’s sleeping.
tedwaltman offline
I have always thought a flight plan was required for overflight of US airspace? That said from Victoria to East Point I have done it many times without one, talking to Victoria Terminal.
The FAA FAQ says a flight plan is required, but I cannot find any regulatory reference number. Anybody?
https://www.faa.gov/about/office_org/he ... filing/faq
“ Q: Do we file an ICAO FPL from Alaska to destination within the conterminous U.S.?
A: Yes. An ICAO FPL is required when crossing international boundaries.”
Canada says a flight plan is required if your destination is a foreign country.
CARS 602.73.
(4) Despite anything in this Division, no pilot-in-command shall, unless a flight plan has been filed, operate an aircraft between Canada and a foreign state.
SOR/2021-152, s. 19(E)SOR/2025-98, s. 27
As Daedaluscan says, we cross into US airspace all the time without a flight plan as long as we’re not landing.
Years ago instructing in the Bell47 we’d fly down to Bellingham and hover a foot off the ground in front of customs, then pull pitch and fly back to Canada. Wouldn’t try that now.
Karmutzen offline
Ted, that's interesting about the fire extinguisher requirement (even if it doesn't apply to U.S. aircraft transiting between AK & lower 48) -- the requirement you posted seems to say that not only do you need one for the crew, but 2 for the passengers from 0 - 60 passengers! So if you have 2 crew (Cub for example), you need 1. But if you have a 4-place airplane you would need 3 (1 for crew, 2 for passengers)! https://fly2ak.com/PDF/CanadianAirRegs.pdf
Christina Young offline
Aircraft: Piper PA-18
Stinson 108-3
Nothing has changed. Doesn't need to be Halon and only need one accessible in the cabin for most private registered aircraft.
Mark Y. offline
Aircraft: Cessna 182B
I am planning a trip to AK end of June. My ELT is 121.5 so a PLB broadcasting on 406 will be required. This one seams to be the lowest cost. McMurdo FastFind 220 Personal Locator Beacon. Amazon has it for $318. With the price that low I am wondering what the drawbacks would be. The user manual says it also transmits on 121.5
