alternator belt squeals?
My Cub seems to have developed a squealing alternator belt upon startup. It doesn't happen all the time, and sometimes it squeals longer than others. Any tips or suggestions on how to get rid of this annoying noise? The airplane starts reliably.
dtmnm25 offline
4
- Aircraft: Piper SuperCub
10515
Tue Mar 14, 2017 12:40 am
If tightening the belt hasn't worked, make sure it's not bottomed out in the pulley. You can't get it tight enough to fix that, time for a new belt.
Terry offline
1365
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 4GzPHI6t1d
Terry wrote:If tightening the belt hasn't worked, make sure it's not bottomed out in the pulley. You can't get it tight enough to fix that, time for a new belt.
X2
5186
Aviation grade WD-40
3801
Cary wrote:Aviation grade WD-40
Don't put that on a belt!
3705
- FindMeSpot URL: https://share.delorme.com/camtom12
- Aircraft: Ruppe Racer
