Amazing RC Flying
Sun Nov 13, 2011 10:07 am
That was great, Thanks.
Desert Rat offline
260
A government big enough to give you everything you want,is big enough to take away everything you have." - Thomas Jefferson
Did you notice near the end, the amount of elevator travel rigged into that little model? And the power to weight ratio means... anything goes.
A bit like we used to see the F-15's go vertical... open up the throttle and then pass through the sound barrier straight up. Fun to watch.
flightlogic offline
616
Most of our IMAC models will hover at around 1/4 throttle. For 3D flying throws of 70-80 degrees are used. Nothing like putting 50+#'s of thrust in a 20-25# plane
akavidflyer offline
521
