Backcountry Pilot • Ammeter fluctuating
Ammeter fluctuating
12 postsPage 1 of 1
Ammeter fluctuating
Just replaced my dead alternator with a rebuilt unit from aircraft spruce. Now the issue is the Ammeter is swishing/erratic or “semaphoring”most of the time the engine is running. Any thoughts of what’s amiss?
Thanks.
Mantoga offline
Aircraft: C-182J
Re: Ammeter fluctuating
Did you replace the voltage regulator too? I’ve seen them do erratic things on their way out.
CenterHillAg offline
Aircraft: J3 Cub
'56 182
CenterHillAg wrote:Did you replace the voltage regulator too? I’ve seen them do erratic things on their way out.
No, I didn’t. Is it common to replace them as a pair?
Mantoga offline
Aircraft: C-182J
If it’s an older regulator it certainly wouldn’t hurt, I had a similar experience and solved the issue with a new regulator.
Aircraft: J3 Cub
'56 182
Check the field sense connection. Otherwise, it can be the solid state regulator was marginal at best.
lesuther offline
Check all your connections. I had a similar problem, thought I isolated it to the voltage regulator connector but it turned out to be loose terminals on the battery. I apparently didn't snug them down after an annual. doh.
BazzLow offline
Aircraft: 180H
Overvoltage sensor was the problem with mine.
Replaced it and steady now.
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
All of the above. :) Start with the free stuff like checking all of the connections for loose terminals. If you find one, make sure the metal is clean since that gap can introduce moisture or small arcs. Give the connectors a good visual inspection for corrosion as well, while the components are usually fine the ring terminals can rust. Replace any you find that aren't in good shape. You should also check the output voltage of the regulator (should be doable on the ground, use extreme caution or get qualified help).
If your previous alternator failed, it may have also damaged the regulator (or vice versa). These are surprisingly fragile components that work well when they work, but when they break it can affect downstream parts and they are intolerant of bad power. Start with the simple stuff and work your way up though.
colopilot offline
Aircraft: 57 182A
Just visited with a friend, commiserating that once again his 182RG is in the shop. A new Plane Power alternator was installed at annual, but not a new regulator, so there's insufficient charging of the battery. Apparently the failing alternator affected the regulator, so a new one had to be ordered. We discussed the same things as in this thread--connections, battery, over voltage, under voltage, bouncing ammeter.
That's why we have idiot lights in cars, so that we can't see bouncing ammeters. If it starts, all is good, right? :mrgreen:
One thing you might try, after checking all your connections. Most regulators have a voltage adjustment. On many of the really old ones this was a electromechanical points thing, but in the 60's they went to a solid state version. The usually is a hole with a rubber plug, which you pry off. Use a non-metalic screwdriver like rod to fit into the slot head of the potentiometer that is inside the unit. hook a meter to the system and run you engine. Adjust it to read 13.5V or what ever is called out for in your manual. It may be cycling due to an incorrect voltage regulation setting for the new alternator. If it works, may save you a dollar or two. One other often neglected item is the noise capacitor, it is supposed to let that mild screaming noise the alternator makes on your radio get filtered off to ground. Bad capacitors cause some unpredictable issues with an electrical system. Nothing to lose by trying.
The connectors that hook up to your alternator do take a beating from vibration, I have had what looked like good spade connectors be just loose enough to make casual connection. So replacing them with good solid spades and solid non-corroded wire connections can make a world of difference.
dogpilot offline
Took ball and went home
colopilot wrote:All of the above. :) Start with the free stuff like checking all of the connections for loose terminals. If you find one, make sure the metal is clean since that gap can introduce moisture or small arcs. Give the connectors a good visual inspection for corrosion as well, while the components are usually fine the ring terminals can rust. Replace any you find that aren't in good shape. You should also check the output voltage of the regulator (should be doable on the ground, use extreme caution or get qualified help).
SUCCESS! In examining the wiring from the firewall to the alternator just about every single wire had crack/missing insulation. Applied shrink insulation in some areas and in others replacing terminal ends and whole wire sections. Started up engine, ammeter rock solid showing initially halfway from “0” to charge and settling down within a min to just the “charge” side of “0”. Thanks for all the advice guys, gotta love cheap, common sense fixes.
Mantoga offline
Aircraft: C-182J
You might think about some fiberglass sheath material for the wires. Chafe and heat resistant.
lesuther offline
12 postsPage 1 of 1
