Backcountry Pilot • Amorphous Maule M7/M6 Rebuild Project
372 posts • Page 1 of 19 • 1, 2, 3, 4, 5 ... 19
Decided to start a new thread for this. Also posting on the Maulepilots.org forum. This first post is a few posts from that site all merged, so forgive the odd language and formatting.
I've decided to jump into the deep end rebuilding my new-to-me M7, making a better plane and making progress towards my A&P. Figured I'd start a thread to document the project for fun and to maybe serve as a reference for others in the future.
It's a 1984, third M7 ever produced, with 1600 original hours on airframe and engine. It's in rough condition but I got it because it's desirable - long wing, no rudder tab, IO540. It spent some years on floats in Alaska, had it's time owned by Jeremy, and then spent 20 years in a New Jersey hangar flying 1 hour per year... if that.
As I picked it up on December 28:
After I decided I wanted to rebuild it, I spotted the M6 fuselage for sale on maulepilots.org and thought maybe I could tie that in. The end result of Mod Kit 57 is an M6 with M7 long wings and big rudder. My proposed end result would be exactly the same, but the path to get there would be the inverse. After talking to Shirley at Maule a bit, they agreed that it should be easy to get approved, so she wrote up a new mod kit for me. So I bought the fuselage. It has nearly all the factory mod options installed since it was rebuilt by Maule. Large left side patroller window in back seat, steel stringers instead of wood, stainless belly stringer, super skylight, rear seat shoulder harness and individual lap belt attachments, dual rear seat positions (fore and aft options), all seaplane mods and welded on mounts. Only thing to weld is some rear grab handles and maybe a mount for hydraulic parking brake if I decide to go that route.
Fuselage in my garage after James' harrowing delivery trip from Seattle:
I fly in Alaska during the summers so that adds a bit of complexity to the situation. I've decided to get as much done on the new fuse before heading north, so when I get back I'll have a higher probability of success in a shorter timeframe. The biggest thing would of course be the fabric.
The fuselage didn't come with doors and my M7 cargo doors won't fit so I bought some used doors off ebay. As everyone knows or has heard, doors indeed take lots of time to fit. I lucked out in that the frames fit great and it's only the hinges that need work. Easy welding project.
I ran the power and ground (in case of future tail-based ADS-B or something) for the rear nav light, installed cable fairleads, elevator and rudder cables, finished fitting rear doors.
Painted vbrace, hinges, cabin steps..
That's where I'm at now. A couple more small things to do then it'll get Oratex in a couple weeks. Will try to keep this thread moderately updated. I lucked out by having a few very key people locally that make this possible, most notably Andy Young. Also, Kasey at Maules has been immensely helpful and communicative getting me what I need.
Planning on rotating the fuse around and painting the tail strut mounts and hinges black on the next set of warm days. Don’t have any antennas to go in the tail but am mounting a plate for the ELT at the top center of fuselage, just behind the cargo area. After 2 months of waiting on a estimated 1 week lead time, I got my extended gear in the mail today. Looks very well made.
Great wx on the front range this weekend so I got to fly the M7 and work on the M6 outside. Met more neighbors the 2 days I had this in the driveway than the past year I've lived here.
Finished all the incidental pre-fabric painting as well as refurbing the rear doors. Had sloshed coroseal through the tubes to stop any rust that may have been happening in there. Prepped and painted them, reassembled all the latching hardware after refurbing it. They turned out pretty well, only thing left on them is to skin them but I'll do that down the road when I make a sheet metal and plexi order.
Fabricated and installed ELT mounting shelf at the top of the fuselage per a Maule drawing option. ELT will be attached to bottom of this, antenna mounted to it pointed straight down inside fuselage. After some reading I grounded the shelf to the fuselage so the whole airframe is the ground plane rather than just the small shelf. This was how my Scout was done as well. Artex 345 ELT should arrive in a couple days so I can install tray and route the remote switch and GPS interconnect harness up to the panel.
Made the mounting bracket for hydraulic parking brake installation (Maule dwg 9117E). I'll have my friend TIG it onto the fuselage when he does the rear grab handles. I have a MIG setup but welding to my fuselage is still intimidating and above my pay grade so I'll leave it to him. I ordered the valve off ebay a few weeks ago, I think it'll be a solid upgrade from the stock parking brake setup which is a tab that locks onto the shaft of the master cylinder, known for getting stuck in the on position.
Also, the oratex is on it's way from Germany!
Right after I posted that yesterday I got a crate from Maule with the rear fuel lines that have to be installed prior to fabric, so I installed those last night as well. They come straight with a bend and bulb at the upper end, and the fire/chafe sleeve along the length. You have to feed them down through the B pillar and bend them as you go.
Crate also contained my new lower instrument panel. Was planning to reuse the old one but there’s be so many blanked out holes I decided to splurge for a new one. Will be a completely new panel along with the upper modular panels Maule offers.
-Asa
Re: Amorphous Maule M7/M6 Rebuild Project
ASA
I was following on maulepilots but this will possibly be better. Looking forward to the build. Should be a great plane
Utah-Jay offline
Aircraft: Bearhawk Companion
Great pics & very informative text.
I'm hoping to learn a lot off this thread.
Thanks for posting.
Thanks for the updates. I suppose I ought to join Maulepilots, but there seems to almost be too little time to read thread the way it is. It sure looks nice.
Quis offline
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.”
-Pratchett
Thanks everyone. Maule has made available every drawing for their airplanes on a USB stick with a searchable index interface and everything. It truly makes a project like this infinitely easier to know exactly how things are supposed to be. It also has all the optional installations like patroller doors, skylights, search lights, etc etc.
I’m an aerospace/mechanical engineer and good with my hands but a project like this would still be very far out of reach for me if it weren’t for the drawings and a few key people who are helping me.
Some good progress lately. I moved the airframe from my house to the airport to start moving towards covering it. I had my friend weld on the rear grab handles from Maule and the hydraulic parking brake valve mount. All work overseen by another M7 (in background). Got those painted up today (beautiful weather) and now have the airframe in a nice heated hangar where we're going to put the fabric on. Got a notification from Oratex that the fabric has left Germany so hopefully we can start in a week or so.
Redneck hay ride to airport:
Welding rear grab handles:
After paint:
Hydraulic parking brake valve mount welded on and painted:
Fancy hangar to continue work:
-Asa
I'd love to stop by to see how the Oratex goes on, but I think I'll probably be out of the country then. Bummer!
Quis offline
-Pratchett
Cool project.
I'm interested to watch the Oratex go on and hearing about your experience with it. i am waiting to start building a RANS S7 and have heard good things about the product.
How are you tracking your hours for working towards an A&P?
slowhawk offline
Any additional information about the hydraulic parking brake? I have the old metal plate that just binds against the cylinder shaft, so I never use the parking brake. Having a functional unit that doesn't trash the master cylinder in my Maule would be great. Is there a way to install the unit in a flying airplane (i.e. without welding)? Maybe I should direct my question to the factory... :?
Flyhound wrote:Any additional information about the hydraulic parking brake? I have the old metal plate that just binds against the cylinder shaft, so I never use the parking brake. Having a functional unit that doesn't trash the master cylinder in my Maule would be great. Is there a way to install the unit in a flying airplane (i.e. without welding)? Maybe I should direct my question to the factory... :?
The factory isn't a ton of help on this because of how rare this installation is. The drawing is on the parts CD (9117E). The valve itself is used in American champion planes, my scout had one.
I think you could do the installation on a covered plane even with the welding. Or, if your mechanic was loosey goosey, I bet you could make it work with adell clamps but it wouldn't be strictly legal because it doesn't follow the drawing. You could get to the area to weld just by pulling up floorboards, and weld it through there too.
The drawing they give out doesn't have dimensions so I just texted david maule and he texted me a pic of it with dimensions. Gotta love the Maule people.
slowhawk wrote:Cool project.
I observed (ever so slightly assisted, maybe sometimes) my friend rebuild his M6 this winter with Oratex. He claims 50 hours of fabric work total. It looks great. The local "expert" with Oratex (Glen Marshman) has an S20 in Oratex that looks pristine after 5-6 years I think. The downside is that there aren't tons of planes that have been running it 20 years like the other fabrics.
I am tracking my time in an excel document. MY mechanic friend (the one who rebuilt his M6) got his A&P this way a couple decades ago and said he would do all the airplane inspections and sign off my logbook time.
My oratex shipment was lost somewhere in Memphis between fedex and customs, so after a month Oratex sent a replacement order. I must say that the whole process was very frustrating. Oratex was helpful but didn't go above and beyond or anything. It finally arrived to it's getting put on now. Nice to see some progress after stalling out for a month waiting.
I'm cracking up at the hay bale ride and the anarchy symbol on the tail stand. Looking good.
After a 5 month absence to fly 600 hours on floats in Alaska which was the peak of my flying career and possibly my life, I return to the Maule.
Finishing up the Oratex was top priority when I returned earlier in October. I had a friend who was supposed to work on the fabric while I was gone but that didn't happen. I'm actually glad as I've really enjoyed learning the new skills.
Currently all 3 large pieces are on the fuselage, all that is remaining is to heat shrink the belly fabric tomorrow and do the finish tapes. I don't think it's possible for Oratex to compete with the show quality cover jobs done by the old timers with shiny smooth perfect paint, but I love the simplicity of the system. Your mistakes show in the final product since there's no paint to cover everything up, so attention to detail every single step is key. I have about 40 hours total into this cover job, expect another 15 or so to finish up. I really like the look of the inside of the fuselage - black with the white tubes.
Here's some random pics from along the way.
Is the black backing an option now? It does look good!
A1Skinner wrote:Is the black backing an option now? It does look good!
The darker colors and silver come with black backside color. The lighter colors (yellow, light blue, red, orange) come with white.
Right on. I've only used the lighter ones. Good to know.
Looks good. Do you have any advice or discoveries on the behaviour of the Oratex that you didn’t read in the manual?
I’m grateful that you posted the blueprints of the parking brake system install. I’m going to be installing that on my Stinson build and you just saved me a ton of research!
VortexAlternator offline
Aircraft: Stinson 108 AKA Skookumchuck Voyageur
VortexAlternator wrote:Looks good. Do you have any advice or discoveries on the behaviour of the Oratex that you didn’t read in the manual?
Glad I could be of help. So I’ve never done any other kind of fabric, and the guy helping me has done 3 oratex planes including another M6 so he had already figured stuff out really. The one thing I’d stress is to really take care in every step. Try to avoid thinking “we can fix that later” or “we’ll cover that up with finish tapes” because it’s not like other fabric - you will more than likely notice your mistakes. It doesn’t take long to finish an oratex plane so make every step very deliberate. Trim around protrusions very carefully so the finish tapes aren’t trying to hide a bunch of things. No paint to cover up scratches and such either.
Other than that it’s pretty easy. I did the belly all by myself, but the sides my friend led the way because the waves/wrinkles that are in it prior to shrinking are scary to say the least haha. I would’ve had no idea how to minimize them before shrinking and then remove them with heat effectively without his experience or a lot of trial and error.
Belly fabric has been shrunk, started covering the horiztonal stabs. After those are done, will be a little rib stitching to do and finish tapes.
While waiting for that glue to fully cure (overnight), I decided to start on the interior and was able to make more progress than expected. I've mostly decided not to do a headliner to give more cabin room. The inside of the oratex and the clean white powdercoated frame are aesthetically pleasing enough not to need a headliner, and I have a super skylight above the front seats so it's really not much headliner anyway.
I had a bunch of 0.028" Kydex sheets so I made up kydex panels. For the Jenny Craigs in the audience, Kydex is half the density of aluminum so 0.028" Kydexis the same as 0.014" aluminum. Maule makes this very easy - all side panels are flat. Without a headliner, my plan is to put rubber channel along the top edges of the kydex which will simply rest on the upper longerons. They will fastened in the numerous places Maule convieniently puts tabs, as well as being held by the trim pieces (planning white painted aluminum) surrounding the left side patrol window as well as the right side door frame. Hard to even tell there is kydex in some of the below pics because it's the same black color as the oratex inside, so here's a pic from my last post to compare to:
Started making templates with poster board - worked great. Every Kydex panel fit first try because I took my time with the poster board. So much nicer than aluminum since you can cut it with scissors or score with an x-acto and snap it along the line.
Posterboard templates:
Kydex (upper pieces held in place by blue tape for now):
On that last pic, I was hoping to make the aft 2 pieces a single piece but my Kydex sheets were 2'x4' which was about 3" too short to make it happen. So now it splits horizontally like Maule intended, at the headliner attachment tab.
The rear wall will be aluminum since there is less bracing back there and also I'm out of large Kydex panels....
