EZFlap wrote:6150 or a modification thereof
lesuther wrote:
6150 would be an expensive choice, but it is easy to work with.
AKGrouch wrote:
As they also say, been there and done that, and it didn't have enough authority. Before we could put a square tail on it, I ground looped it and it now lives in the Calgary area.
EZFlap wrote:
Howdy 'Grouch, did you try the VG's on the swept tail to see if that gave you back any of the rudder?
AKGrouch wrote:....Looped the bast#$* first. It had a definite xwind problem and always tried to go left on a wheel landing. Something was tweaked but we couldn't find it to correct it.......
hotrod150 wrote: Did you ever check the wheel alignment? Incorrect castor (aka toe-in/toe-out) has caused many a groundloop. I beieve it is the main reason for the Pacer's bad reputation. I have flown Pacers with the castor set correctly and they were a joy to land. Excessive toe-in or -out is easily corrected on a Cessna using the factory tapered metal axle-mounting shims, although it can be a lengthy trial-and-error process. Lack of wierd or excessive tire wear is not proof that the toe-in/out is set correctly.
EZFlap wrote:I have a few questions for experienced Cessna operators, rebuilders and mechanics:
In studying the 180 landing gear box parts I got from a junkyard in Canada, and after researching a few steel landing gear failure analysis papers, I have three questions ... thanks in advance. Your assistance will result in more/better/cheaper PMA replacement parts in the field applicable to 170/180's.
First question... There are shims that get tightened into the gap above the landing gear leg, in the outboard "slotted" gear bulkhead. These shims are obviously there to take up any up-down play or wear after years of landings. Clear enough. But there are no shims at the forward and rearward edges of the slot in the outboard bulkhead. So any play or wear at the front and rear of the slot would simply get worse, and allow the gear leg to move fore and aft. in the slot, with the gear leg "rotating" around the inboard vertical attach bolt.
So my question is whether the Cessna design simply relies on a tight fit as you slide the gear leg into position, and allows the edges of the steel gear leg to pound on the edges of the slot. Or is there some shim or other "centering device" that I did not get in my goodie box form the junkyard?
Second question for those with experience... if you were going to make up a new gear box for the 170/180, what would you do different than Cessna did?
Third question. Can anyone on this forum provide me with accurate dimensions and/or a copy of the drawings for the late 170 "Lady Legs" and/or the early 180 gears? I know I can ask Cessna for the drawings, and they will either tell me to pound sand or pay a large amount of money. I'm tryin' to get around that problem without too much re-distribution of wealth
side slip wrote:
Nope, you are not missing any pieces. The gear leg just slides in, not particularily tight.
The only other shims in the system are ones that go under the inboard end of the leg to level the wings within tolerance.
