Zzz wrote:BigRenna posted some photos a long time ago of a lift he has in this hangar, this big Harbor Freight monolith that looks like the Arc d'Triumph called a gantry crane. You lift at the base of the engine mount (after de-cowling of course.) It seemed like a solid and stable method to me. If your hangar has well positioned I-beams you might lift from those with a block and tackle or a fancy remote controlled hoist. Whatever it is, it should be something you can lock/secure.
If it hasn't been done, a good inspection of the gearbox and gear leg might be in order. Probably fine but you never know and what better time to do it?
More ideas:
https://www.backcountrypilot.org/forum/ ... aggs-15976
bart wrote:Not sure if this process will work with a 182, you know, since the little wheel is on the wrong end.
8GCBC wrote:Not a Cessna but, ....
A couple of portable aluminum gantry cranes use the engine mounts and a hard point on the empennage. The only caveat is the center of gravity is above the lateral lifting line. Which is why I drain the tanks and attach small weights on ropes to the wing tie downs (keep things stable). I can use just the engine mounts to lift and remove the MLG only. Very happy with the arraignment and it is semi-portable. I have lifting rings installed but, do not like using them (hard to center).
Circa 2013, amphib swap 8GCBC:
hotrod180 wrote:One of my hangar neighbors has a GlasStar with lifting eyes. He used an overhead chainfall & a spreader bar arrangement to hoist it up to change wheels or something and left it that way overnight. Came back the next day to find the airplane heeled over to one side and a whole lotta gas on the floor. Not good!
SKYLANEDAVE wrote:Thanks, I really do need a newer maintenance manual as the original one lists some questionable procedures. Interesting about not lifting one side.
