Any word on electric MTV-17?
Sat Apr 18, 2026 11:54 am
Anyone flown it, own it, or heard anything?
Electrically controlled constant speed prop.
Thanks!
Dan
Ace007 offline
76
- Aircraft: Cessna 180
Sounds cool. Would be a nice option for those with solid crankshafts.
Has there ever been an electrically-controlled variable pitch prop for any certified aircraft?
2988
- Aircraft: None
I think the earliest Bonanzas were equipped with electrically adjustable props that evolved into a true constant speed mechanism. But I’ve not seen one. Just read about them.
https://www.bonanza.org/globalassets/mi ... ration.pdf
Belloypilot offline
120
- Aircraft: Husky A-1B, Bonanza V35B, AcroSport II
Ace007 offline
76
Looks like one of those rare instances where it’s approved on cubs in another country but not the USA.
I’m very curious how it’s controlled, a rheostat on the panel and slip rings like an electric deice boot? How much current does it draw? Is it a true constant speed or an inflight adjustable pitch?
Interesting…
Halestorm offline
958
- Aircraft: C-182E Pponk
There are a couple FAA STC’d electric props (look for the MTV-18) for a 172 and PA-28.
I’m thinking about buying this for my new 175hp O-300.
Talked to a guy who flight tested it and was offered a field approval but wanted an STC.
One controller version has a constant speed function. Uses brushes.
Ace007 offline
76
Sun Apr 19, 2026 10:29 am
Let's say there's an STC for the MTV-15 on your bird, but none for the MTV-17, so you decide to try for a field approval using data from the -15, or similar approvals of the -17 on similar airframe/engine combos.
Chance of success? How useful is EASA data in a FAA field approval?
2988
- Aircraft: None
Electric controlled prop is available by STC for Grumman Tiger O-360 engine.
48Stinson1083 offline
88
- Aircraft: Stinson 108-3
