While that steep a descent rate sounds like a lot, since we typically go down at 500-1500 fpm, if it were only straight down, those speeds aren't all that fast--only 86-135 mph vertically. However, in a spiral, with that much of a descent rate, it's entirely possible to go much faster than Vne. Any time a slickish airplane, such as a Comanche, Mooney, Bonanza, gets pointed down too steeply, going well past Vne is very likely, and then parts start shedding. Spatial disorientation often leads to a graveyard spiral, which typically involves a descent angle of 30-35 degrees. I don't remember enough high school math to calculate the speed in a 30-35 degree downline necessary to have a 135 mph vertical speed, but it's darned quick. A non-instrument rated pilot, even one with plenty of experience, theoretically has only 178 seconds to live after entering IMC, and a dark, overcast night is effectively IMC:
http://www.aopa.org/aopalive/?watch=h5d ... 4GMGDISx39Scary stuff.
