As to mentioned Depleted Uranium ("DU"), while the density is similar to tungsten & hardness is high [ref https://www.osti.gov/servlets/purl/6133316 ] I have never seen a DU bucking bar. I expect the required special shipping & handling costs would be expensive.
Depleted Uranium is dense enough and plentiful enough that some serious ocean racing sailboats used it for their ballast keel. Most notable was Pen Duick VI. The minor amount of radiation emenating from the DU is easily shielded by the water. It might even slow, or prevent marine growth on the keel bulb. Not that any of that helps with bucking rivets...
I have 5 custom bucking bars and probably 20 steel. the tungsten bars do 99% of the bucking in my shop. I only use the steel bars these days to get to weird places I can't get a tungsten bar to.
I would be curious to see what your favorite bucking bars look like. I don’t have a ton of riveting experience. Seeing what those who do have experience use, might be helpful.
Good thread, I had been wondering this. Solid rivets that you can't use a squeezer on are few and far between on Maules (except wings), so I just bought a starter kit from ATS, it only came with steel bars. Would be interesting to try Tungsten sometime.
No question at all, a resounding YES from me. Especially in hard to reach places where you can’t get much pressure on the bar. Tungsten bars just make the job so much easier. One of my favourite is a little 1”x1”x3/4” block. Bucked a lot of air tractor leading edge rivets with that little bugger.
12.22.2013 - Initial article format Operating aircraft on skis and negotiating a snow-covered landscape is an entirely unique skillset and environment.…
