Backcountry Pilot • Auxiliary Fuel
Auxiliary Fuel
24 postsPage 2 of 21, 2
Re: Auxiliary Fuel
If I pump my Nauta (brand) fuel bladder dry, it will briefly make the engine run rough, but the instant I shut the transfer pump off it resumes normal operation, really a non issue. Nonetheless, after 22 years of flying fairly often with a portable ferry tank of various kinds, I choose to initiate the fuel transfer process at cruising altitude, rather then approaching a gravel bar. That makes the entire discussion of what position any fuel selector/which tank should be in irrelevant. KISS!
Re: Auxiliary Fuel
asa wrote:
Aryana wrote:
hotrod180 wrote:
bat443 wrote:.... You would still want to burn fuel from the tank you are not transferring to as the point is to not introduce an air bubble into the operating fuel stream if the aux tank runs dry. .....
This discussion, and esp this comment, brings to mind the recent forced landing into a river by one of the youtube guys in his Cub.
https://youtu.be/QJrVUZKcxrU
Ouch, but good video.
Fun to watch, you mean...
Watch your insurance premium soar when you install bushwheels.
Re: Auxiliary Fuel
I've never had an insurance company ask what size tires I use
Re: Auxiliary Fuel
courierguy wrote:If I pump my Nauta (brand) fuel bladder dry, it will briefly make the engine run rough, but the instant I shut the transfer pump off it resumes normal operation, really a non issue.
I was wondering about that? I have deliberately run a wing tank dry in the climb to see how quickly it would change over and get back to full power. It caught surprisingly quickly and was a none event. Hardly lost any height, but i was expecting it and changed tanks quickly.
JamieG offline
Aircraft: C180J, O520
