I am curious to learn what BCB members are running and what you all believe to be the ideal avionics setup for various crafts and missions. Obviously, one would probably never install a Garmin 530 in a J-3, and you would likely not set up a C206 with just a flip/flop COM.
I am planning on installing in my 67 C180H: a Garmin 480 with a mode C transponder. I would love to install a GTN650, SL30 NAV/COM and Mode S, but that would cost ten times as much as what I am doing, and weigh several more pounds. The CNX80 is a WAAS GPS/NAV/COM and will be coupled with a Garmin GI-106A CDI/GS. For me this setup will strike the balance between high capability/functionality and light weight. Running this with a handheld radio for COM redundance and an iPad with a GPS should provide me with all that I need for light IFR work and VFR adventuring. What is the value in having another NAV/COM, CDI, Audio panel, MFD, etc... Any advice on "must have" additions to this setup is highly encouraged.
What are you using?
