Jasers wrote:What happens in March, Barnstormer?
whee wrote:Very cool plane. I too like to rudder pedals, keeps the floor clean and solid. I like to long wing is another feature I like. It made me think twice about my planes to eventually buy a Bearhawk kit...then I saw the price tag for the BOSS kit, 60K
A1Skinner wrote:Is the bearhawk kit much cheaper? By the time you buy fabric, windows, etc. If this is all included in the SQ then the price wouldn't be much difference.
Crzyivan13 wrote:Jasers wrote:What happens in March, Barnstormer?
Barnstormer takes delivery of his new to him SQ2.
Barnstormer wrote:Crzyivan13 wrote:Jasers wrote:What happens in March, Barnstormer?
I bought Randy Goza's SQ-2. Randy and I are bringing it down from Alaska in March when there is a weather window.
but it seems to me the main reason for going 4-place over 2-place is load / family hauling capability, and for some people, getting there a little faster too.
Bear_Builder wrote:Most of the Bearhawk's speed over Cub based aircraft comes from the reduction is parasitic drag. 1 strut instead of 2, no jury struts, no cables or pulleys exposed, no hinges hanging out in the breeze, no fat bungies out in the air stream etc.
Battson wrote:One other thought to further confuse the mix, the longer wingspan might allow for higher speeds at high altitudes, depending.
Zzz wrote:Battson wrote:One other thought to further confuse the mix, the longer wingspan might allow for higher speeds at high altitudes, depending.
Blaze your way through the stratosphere in the all new 4-place Super Cub!
Battson wrote:Bear_Builder wrote:Most of the Bearhawk's speed over Cub based aircraft comes from the reduction is parasitic drag. 1 strut instead of 2, no jury struts, no cables or pulleys exposed, no hinges hanging out in the breeze, no fat bungies out in the air stream etc.
*Almost* no cables and pulleys exposed![]()
I wish I made those fairings before I flew, they are soooo hard to get around to making afterwards!
I was interested by your perspective on the speed increases. I would like to think all that work with the flush-riveted wing pays off... But my guess is it's simply a horsepower thing?
Maules have the dual strut and a few other non-aerodynamic cub-like features, and they achieve similar speeds. I'd hazard a guess that a 260hp Citabria would do similar speeds too.
But the main thing is you're not going 80kts x-country!
I note the BOSS spec-sheet doesn't boast about the cruise speeds - does anyone know what airspeed it can achieve at a certain throttle setting?
...While I'm being biased and obtuse, reading the spec-sheet I noticed the Bearhawk only needs 20ft more take-off roll that the SQ4 when loaded at MTOW, 200lbs heavier than the SQ4. All that wing is no substitute for raw horsepower....
