Backcountry Pilot • Badazz flying!
Badazz flying!
5 postsPage 1 of 1
Badazz flying!
Not an accident, but would have been if a mere human was behing the controls. :shock:
This is from AvWeb. The report is a fun little read.
August 5, 2017, Pocatello, Idaho
Lockheed P2V-5F Neptune
The airplane was substantially damaged shortly after takeoff. The airline transport pilot, commercial pilot and passenger were not injured. The airplane was operated under contract to the U.S. Forest Service to provide aerial application services (e.g., firefighting). Visual conditions prevailed.
According to the pilot-in-command (PIC), he observed an uncommanded aft movement of the control yoke with a simultaneous increase in the airplane’s pitch attitude during initial climb. Despite multiple attempts to regain control, the airplane continued to maintain a nose-up attitude. Five degrees of flaps were deployed, which reduced the elevator backpressure. The PIC subsequently jettisoned the load of fire retardant over vacant land and the flight declared an emergency with ATC.
The PIC had previously demonstrated approaches to land without making any adjustments to power or pitch, so he configured the airplane for an approach without trim or elevator control. They flew a wide traffic pattern and made small adjustments to compensate for altitude. During the final approach leg, the PIC used a combination of wing flaps and engine power for pitch adjustments, and the crew coordinated application of elevator and turns to make their pitch-down adjustments. A landing was accomplished without further damage. Investigation revealed a bolt in the airplane’s pitch-control system had backed out. It had not been safety-wired.
Mountain Doctor offline
Aircraft: Maule MXT-7 180A
Re: Badazz flying!
Yikes!!!
I had a screw back out on the upper side of the tailcone on a Cessna 401 that then hit the bottom of the rudder, which prevented any right deflection of the rudder. Left rudder full travel, right rudder... Clunk, nothing.
Got my attention, but certainly not like if it had been the elevator.
Re: Badazz flying!
I hope that Neptune drivers boss gave him a bonus, a day off and a few free drinks
Good save!
Re: Badazz flying!
+1 on that and probably owes the flight crew new underwear. :shock:
TomD offline
Aircraft: Maule M5-235C
Re: Badazz flying!
Some of us are mere pilots. There are some out there, though, who are true aviators, right?
5 postsPage 1 of 1
