Backcountry Pilot • badger hole getter outer
5 postsPage 1 of 1
The problem:
The solution: An 8 dollar 500 lb. pull block and tackle (from Harbor Freight, so you know it is top quality) with 60' of rope. An entrenching tool, U.S. Government made, by the lowest bidder. I've had it forever, so free. Ziptied and taped together, and mounted semi permenantly in the rear baggage compartment (won't do any good sitting in the hangar, I may take it out when planning to ridge soar deadstick or not going off airport). Total weight less then 5 lbs. That and my super sharp 1.5 lb hatchet, with the hammer head for the tie down spikes, also handy for other purposes.
I got it out this time by noticing the hole, which was real steep the way I hit it, was more gently sloped (on the left), so I rotated the tail 90 degrees, (luckily no obstacles prevented that) and was able, just barely, to pull it out. It got me thinking... with this kit I now have I could chop out a ramp and/or use the block and tackle. I also have a short cable choker for misc. rigging to a hard point if need be. These damn holes were everywhere, and big enough for a bassett hound, so I am assuming badger, luckily not home at the time.
Re: badger hole getter outer
Fisherman offline
Wudja taxi into that hole for? Look at all the work you made for yourself! Stinking badger hole!
Glidergeek offline
Aircraft: 1968 P206C
DG 400
Glidergeek wrote:Wudja taxi into that hole for? Look at all the work you made for yourself! Stinking badger hole!
That's what I was asking myself! As I recall I was looking behind to keep the tailwheel out of another, I mean it was a real obstacle course. No excuse though, I had already navigated through the worst of it and thought I had it in the bag, and got a little careless and/or cocky.
My real fear was pissing off the badger, I've been face to face with them before and there is nothing more vicious and fearless, only getting behind a steel door real quick saved me the last time, I mean he wanted a piece of me! If I hadn't got out within 10 minutes or so like I did, I was sure he was going to decide he wanted out of his hole, and the easiest way would be through the Airstreak tire. #-o
I'm guessing you must have been down to a crawl when you went in the hole? I sure wouldn't want to hit one on roll-out-- looks lke that'd put you over on your back quick as a wink. "Oops"....
5 postsPage 1 of 1
