bfmetcalf wrote:A couple of Garmin GI275's will let you keep the round steam gauge look and still give you the glass info/capabilities.
I assume you're experimental, and if so, you could also look at the Garmin G5. If your need for WAAS GPS is for instrument approaches, you're going to need an IFR navigator anyway, so why not go Garmin for both.
Battson wrote:I bet you know this already, to fly single pilot IFR in the Bearhawk means a full autopilot.
jugheadF15 wrote:Battson wrote:I bet you know this already, to fly single pilot IFR in the Bearhawk means a full autopilot.
Why would it mean an autopilot. I don't get pilots that think one can't or shouldn't fly IFR without an A/P. Every single seat fighter is flown IFR without one everyday at 300-450kts on a single radio and single nav source. Believe me, that is much more challenging than plodding along in a Bearhawk at 125kts.
JP256 wrote:.......I had a "wing leveler" in a Grumman Traveler in the past, and although most people laughed at it, I found it invaluable on VFR cross-country flights.....
The Trio or Tru trak are quite affordable and can be driven off of a handheld GPS. They can also just be used as a wing leveler with the heading bug right on the control head. Easy install with them as well. May be worth looking in to.hotrod180 wrote:JP256 wrote:.......I had a "wing leveler" in a Grumman Traveler in the past, and although most people laughed at it, I found it invaluable on VFR cross-country flights.....
I'm a VFR only pilot, and I would like to have a single-axis aka "wing leveller" autopilot.
It could be driven by my pre-STC G5, or simply by dialing in the heading.
Unfortunately simple single-axis autopilots seem to be few & far between now,
and I'm not interested in spending $10K or more for something like Garmin's "affordable" GFC500.
Trio uses a push pull rod in the wing and tail. Very simple and easy to install.hotrod180 wrote:A guy I know has a Bushmaster with a single-axis TruTrak autopilot.
One servo, which mounts on the control column & has a sprocket which engages the aileron cable chains.
And a controller head that looks like an artificial horizon into which you can dial your heading.
Very simple.
The TruTrak & Trip AP's both seem to be more affordable than the Garmin.
Their AP's for certified airplanes are both two-axis models,
and appear to use traditional servos which mount further out on the aileron & elevator control systems.
Not as attractive an option IMHO.
